theweinerback
Steven
Orlando, FL
Installed a Bedrug and removed the front and back graphics. Peeling off a $750 sticker felt strange but I like it much more without them. The side ones will stay... for now
Not my finest handiwork on the Bedrug lmao but I needed a solution quick with a gig coming up this weekend I'm hauling guitar cabs and a drum set for. May pull it out and add a spray in at some point.
Now if I could just get past the option (and wallet) paralysis with the tonneau covers...
Ford Ranger What did you do to your Ranger Raptor Today? IMG_9053
Ford Ranger What did you do to your Ranger Raptor Today? IMG_9054
spellchek
earth
'23 Ford Bronco
They are great tires. The only LT Flotations I found with R speed rating and lighter weight with a good reputation. I don't get much rain where I live in the high desert, but with it still being spring I should get some chances to see how it goes.
RT are more aggressive (hybrid AT/MT) vs. an AT tire like the OE KO3s, so there is more road noise. The gaps between lugs are much wider which catches air and creates noise. Not unbearable like MT style tires though. I've only got about 100 miles on them so they are still breaking in. The extra width definitely improved dry traction - I used to break the rears loose easily, and now it takes some serious effort (FP Tuned/Sport mode).
Chunky.
quickstang1
Cypress
Just have this close up comparison. I’ll try to take more later
Very happy with it though. Very bright and sleek. Morimoto gear is pretty high quality so I’m expecting it to last the life of the truck
How was the install?
SolarWinds
PNW
IT Director
Not bad. 30 minutes to an hour
Remove 4 screws, back out the light disconnect the cable, pull the very back of the headliner (not as bad as it sounds), replace the pigtail connector, reconnect it to the new light, and then wipe down the install service and put it into place.
Probably the best visual improvement to the truck for the money. Very happy with it. I had to pull some bags of mulch out of the bed last night and this light lit up the area perfectly.
rwolfcastle
Took off the Relation Race Wheels and installed Ford Performance Method 703's
Are these the stock tires? Do you have a view from the front or rear to see the "poke"?
Catalyst
Justin
Bend, OR USA
Network Engineer
Yeah they look great. I’m guessing they’re +30 or +55 since they’re a purpose-built wheel. I'm not a fan of the training wheels look of the +0 and negative offset.
Good guess... they are 17x8.5 +35
SurfRanger
Ben
Orange County, CA
2020 Ranger XLT Sport 4x4
Product Design Engineer
After multiple hours and Modelos in the driveway I got the Decked Drawers in the truck and modifications done to it for my water lines.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_3666
Ford Ranger What did you do to your Ranger Raptor Today? IMG_3662
gapiel
Greg
Charlotte NC
Installed RANGER Tailgate emblem, Good Year in-channel wind deflectors and Husky Mudflaps
Ford Ranger What did you do to your Ranger Raptor Today? IMG_0014
Raised Gloss Black emblems from Etsy
Ford Ranger What did you do to your Ranger Raptor Today? IMG_0019
