2.3L and 2.7L Engines
Rando
The 5g has the 10r80, are they taking it down to the 10r60 for the 6g? If so, source?
Yep. In this video he was told (presumably by the Ford marketing team that’s there with him in the background) that the 10r80 was dropped across the whole line for the 10r60 (for the US gasoline engines at least, as the diesels get the 10r80 in the rest of the world).
LethalGuineaPig
2020 Ford Ranger XLT
Man... Thanks for the video. I don't know how to feel about it. On one hand I've heard the 10r60 has smoother shifting, but the 10r80 is beefier and used in the F-150.
Scooter
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
As long as you are not tuning the 2.7L the 10r60 is fine. I scanned the internet and could not find many problems with the automatics on the Bronco. . In the beginning they did have a clunking issue but that seems resolved. It looks like you have to be easy on the tranny when putting it in gear, letting it engage.
LuckyMonkey7
TX
2002 Lightning
10R60 has a max torque spec of 600Nm which is 443 ft/lbs
2.7 has a max output of 415 ft/lbs on premium fuel
If I go with a ranger, a tune is definitely on the table. As well as other power/reliability related mods
APmech
Cal
21 Ranger Lariat
A&P mechanic
It looks like the 2.3L clutch fan has been thrown back in the 1970's parts bin. That should be a nice improvement.
Chris D Hall
Amarillo, Texas
F150 and Edge
Network Operations Manager
The 2.3 is enough for anyone using the truck for it's intended purpose... that being said I'm taking my talents to the 2.7. I want more power without a tune because... I just do. I'll also be running larger tires than stock. It should sound better, and I think the 2.7 has both direct and port injection which is a huge benefit imo.
fordtrks4ever
Perkiomenville, Pa
I want the 2.7tt
Scooter
Scooter
--Machinist
What's the huge benefit of the direct and port injection. The main benefit is that it washes the top of the valves. Prevents carbon build up over a long period of time. Maybe if you were going to change the injectors it may give you access without taking the motor a part.
Mock01
AZ
2022 Ranger
What about the 3.0 in the Raptor? Supposedly coming with 430 ft-lb of torque. The internet says the 10r60 maxes out at 443 ft-lb. That seems awful close. Then again, the Bronco Raptor makes 440 ft-lb and also has the 10r60 so…
Scooter
Scooter
--Machinist
Does the Raptor not use a different tranny. I think it has the 10r80
Mock01
AZ
2022 Ranger
I looked at the Bronco forums and it looks like the BRaptor uses the 10r60. I assume the RRaptor wouldn’t be any different, especially given that it’s the same engine but slightly detuned.
Scooter
Scooter
--Machinist
Is it a modified transmission or the same one in the standard Ranger.
