2025 Ranger Raptor Auto Start/Stop Disable In Forscan
Amd the 18 dollar amazon auto start kill unit also has been trouble free for my son and i since i installed them half a year ago
SubZombie
Virginia
I thought this was common knowledge? Even a quick search when I got my truck and was looking at them everything I read said they all constantly pull some power when the truck is off, and that was backed up by YouTubers I saw noting it when they installed them and people on car forums like this as well. From what I've seen you're very unlikely to have issues while the battery is less than a couple years old unless you constantly leave it sitting for a long period of time or make frequent short trips, but as it gets older you have to be careful.
kevinmxz700
Kevin
ontario, canada
f150
manager
Is it possible to change temperature range when feature is activated? If it doesn’t start working till engine is warmed up, can you not change value to an unattainable number?
Oh man, thinking outside of the box. Great idea
JimG
Jim
Scottsdale, AZ
2025 Ford Ranger Raptor
Has anyone found the process for disabling the auto start/stop feature for the 24/25 Ranger Raptor in Forescan? I know it can be done so I'm looking for which module and bit value to change. I have the 4D-Tech auto start/stop eliminator cable but these use battery power all the time so if the truck sits for more than a couple of weeks the battery starts to go dead.
There is a way you can turn off the auto start stop without ForScan on RR. Push the Raptor button on the right side of the steering wheel. In the raptor drive mode you can set you preferences that will be saved every time you choose to drive in Raptor mode. To set up: press the R (for raptor) on right hand steering wheel. Then press the A button on the center console. It should say on the driver instrument cluster auto start stop deactivated. Now with the other buttons on the right hand side of the steering wheel you can set the other preferences you want. Push the steering wheel and choose an option . I have comfort. Push the Shock button for the ride you want. I have mine sporty. Push the exhaust button and choose the sound you want. The with the console dial you can choose the 2 or 4 wheel drive. I have 2 wheel. When you have done all that push and hold the Raptor button again for 3-5 seconds. If it all takes you will see a red R in the back of you truck on the drivers instrument on panel. Now you all set. Then every time you start the truck push the Raptor button 2X on the steering wheel all your saved parameters will engage. If you ever want to change them just do the process all over. This is also explained on page 265 of the owners manual. Yes you will still have to push a button twice, but you get all the other choices automatically. I believe it’s a great trade off.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
Yeah, removing the 4dtech module did nothing to my battery drain issue. A full week of driving 25+ miles a day and ASS never once triggered, always due to "vehicle charging".
Think I'm still going to leave it out until I take it in so Ford can't try to tell me that's the cause. Probably not going to take it back in til the airbag recall however.
I will note that I confirmed mine doesn't power up until the truck does, so if yours turns on the moment you plug it in you might want to ask 4dtech what's up.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
So long delayed update, my battery drain issue did in fact end up being a faulty battery. Ford tested it when I took it in for the airbag recall and found it failed. After replacing it my battery drain issue went away. I've since reinstalled the 4Dtech module and so far haven't had any issues with drain.
KayaPayaPigDog
Kyle
www.youtube.com
US Navy
That’s good news! Glad you got it sorted.
cheers
alrashid2
PA
Did any of you try turning auto start stop off using FORScan?
ZombieDropper
ZombieDropper
JĂĽrgen
Phoenix, AZ
Facilities Manager
As far as I know they haven't written or discovered the code for that. But now that auto start/stop is being taken off US cars the dealer might be able to do it for a fee.
alrashid2
PA
Hmm, I was looking in the FORScan crowdsourced excel and there is a line for it?
ZombieDropper
ZombieDropper
JĂĽrgen
Phoenix, AZ
Facilities Manager
That one doesn't work. It causes all kinds of problems with your display.
alrashid2
PA
Weird, why is it listed as approved in the sheet then? Makes me worried things arent being updated
ZombieDropper
ZombieDropper
JĂĽrgen
Phoenix, AZ
Facilities Manager
I know. I tried some others off that sheet and they didn't work. I think the cable from 4D Tech for $100 might be your best bet for now and it's a 1 minute install.
Or the 40 dollar amazon dongle. It works just as well
