Aftermarket rear diff cover Non raptor
24Cactus
orlando fl
2024 XLT FX4
Hi all, just wondering if they make a aftermarket diff cover for a non raptor 2024 fx4 with the locking diff. I found one on fords website it shows it fits 24 broncos non raptor and up to 23 rangers. I don’t want to buy it and it not fit. I already dented and replaced my factory cover once. Any help would be appreciated.
Ford Ranger Aftermarket rear diff cover Non raptor IMG_8615
Hootbro
Delaware
2024 Ranger STX 4X4
That is a good question. I know on the 2024+ Ranger, they install a different metal standoff bracket on the left side of the cover than on the 5G and current Bronco and would be suspect if it actually fits?
Looking at the actual Ford Performance Parts website, they stop at 2023 for the Ranger application.
josephp732
Joe
NJ & FL
I am very interested in this also. Google AI says the 2025 Bronco and Ranger both use the Dana M220 differential. Ford parts sites only show the Ford Performance M-4033-BR M220 HD Rear Axle Differential Girdle Cover as a Bronco fulfillment. The American Truck website show that it will work on the Ranger. Hootbro might be right here is a picture of my 2025 Ranger's cover, the stand-off bracket looks like it would not mount flush to the Ford M220 performance cover because of the aluminum support arm that's between the two bolts on the left side of the cover. The bigger question is why did Ford delete the drain plug on the differential for the 2024 and 2025 versions! And my cover has to be the worst paint job ever with so many massive runs.
Ford Ranger Aftermarket rear diff cover Non raptor 20250624_201136
Ford Ranger Aftermarket rear diff cover Non raptor Screenshot 2025-06-24 211615
Ford Ranger Aftermarket rear diff cover Non raptor Screenshot 2025-06-24 211713
Hootbro
Delaware
2024 Ranger STX 4X4
Drain plug was deleted around 2021/2022 on both the 5G Ranger and Jeep Wrangler/Gladiator that used the M220 DANA differentials around the same time. As to the why, could not tell you but I suspect since it happened to both Ford and Jeep at the same time, might have been a cost savings pitched by DANA.
i haven't gotten under and looked so this might a dumb question but was the drain added to the body of hte diff instead of hte cover? maybe its on the bottom of the actual diff housing? thats how my nissan titan was
Hootbro
Delaware
2024 Ranger STX 4X4
There is no drain plug/hole on the M220 differential.
Awirez
Doesn't look like MB3Z4033A is anything special, nor the KB3Z4033A. The bracket looks to be using studs in place of bolts.
I'd imagine as long as it's for the M220 the immediate concern would be any aftermarket flange thickness, primarily where studs are used. If the flange is thicker than OEM the position of rigid lines could be shifted.
I think the issue with to Ford Performance one may be the casting interference with the bracket mount.
For future purposes, I'd like to find a cover with a drain plug too.
Ford Ranger Aftermarket rear diff cover Non raptor 1750871832778-vz
Ford Ranger Aftermarket rear diff cover Non raptor 1750870716443-f
Ford Ranger Aftermarket rear diff cover Non raptor 1750871165996-
Ford Ranger Aftermarket rear diff cover Non raptor 1750871863831-8v
Ford Ranger Aftermarket rear diff cover Non raptor 1750872230267-7c
Awirez
ARB has one for the Dana 220
https://store.arbusa.com/differential-cover-0750012/
They don’t say it fits the next-gen Rangers, but they literally have a picture of it on a new Ranger. YMMV of course.
Found the website article. They elected to not mount the brake hose bracket to the diff cover since they use socket head cap screws. ? The stock photo is advertising the bumper. Deceptive, nonetheless.
A New Era of Overlanding - The Next-Gen Ford Ranger | ARB 4x4 Accessories
Ford Ranger Aftermarket rear diff cover Non raptor 1750874354643-g1
Ford Ranger Aftermarket rear diff cover Non raptor 1750874304903-r
josephp732
Joe
NJ & FL
I talked to Yukon - their cover should work. The image does not show a drain plug but I was told that images are of first production run from 5 years ago and that the cover does indeed have a drain plug.
Ford Ranger Aftermarket rear diff cover Non raptor Screenshot 2025-06-25 141728
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
Awirez
The Yukon cover is using socket head cap screws to. I could see the covers working if someone figures out the correct fastener to use where there are studs and maintain the approximate proper standoff.
I bet Ford says you need to replace the plastic tube supports when you remove the diff cover. Or maybe they could be unthreaded off without damaging the barbed retainers too much.
I would think the best option thus far is the Ford Performance cover and then cutting a relief in the steel plate to allow clearance for the diff cover.
I don't have the time to buy and try, however. I'll probably wait for a better solution.
Ford Ranger Aftermarket rear diff cover Non raptor 1750966924826-jx
Ford Ranger Aftermarket rear diff cover Non raptor 1750966968728-1u
Ford Ranger Aftermarket rear diff cover Non raptor 1750966992319-2
Ford Ranger Aftermarket rear diff cover Non raptor 1750967035872-89
Ford Ranger Aftermarket rear diff cover Non raptor 1750967602108-wy
josephp732
Joe
NJ & FL
I took a shot and used my Ford Pass points and ordered the Ford Performance differential cover. Looks like I will be modifying the brake bracket! Does anyone know the torque specs for the cover bolts?
josephp732
Joe
NJ & FL
So some very good news. I received the Ford Performance differential cover today and low and behold it comes with 2 longer bolts and spacers for mounting the brake line bracket that's on the 2025 Rangers :). There is even a page at the end of the installation guide that tells you to use the 2 included longer bolts and spacer when installing the cover on a Ranger. See attached image from the installation guide.
Ford Ranger Aftermarket rear diff cover Non raptor Diff 2
Ford Ranger Aftermarket rear diff cover Non raptor Diff 1
