Ambiant lighting and driver seat
Wags
PA
2024 Ranger Raptor (Soon)
Does anyone know if the RR has interior Ambiant lighting that lets you change the color? Also with the driver's seat, does it slide back when you park and get out and slide back when you get in automatically?
tbalt14
Tom
IL
2022 Ford Ranger
Electronic technician
It has the ambient lighting.
Ford Ranger Ambiant lighting and driver seat Screenshot 2024-01-16 at 5.30.20 PM
olefordguy
Craig
Alabama
I'm pretty sure the ambient lighting on the Lariat and Raptor lets you adjust the brightness but does not offer different color choices.
0ak9
GA
In the RR, your seat will automatically slide back and then back to your saved preference once you start your truck. You can also turn this feature off if you want.
Lariat does that too and also has 3 other settings.
jrRaptor
Maize, KS
Ambient lighting is kind of a yellow orange color. Lights are located in the door panels, center console by the phone cubby, and below the upper glove box. You can change the brightness in the infotainment screen but not the color.
Driver's seat has easy entry/exit that can be turned on or off also through the infotainment screen.
I'm curious if the LED's are white with a colored cover or if multicolor and if it can possibly be adjusted in FORSCAN.
jrRaptor
Maize, KS
Played around with FORSCAN a bit and was able to get this screen
Ford Ranger Ambiant lighting and driver seat 20240726_193628_resized
But as you can see, selecting a different color had no effect. ☹
Ford Ranger Ambiant lighting and driver seat 20240726_193701_resized
Ford Ranger Ambiant lighting and driver seat 20240726_193652_resized
Stumpm2
Wyoming
Ranger Raptor, F350 Tremor
You need to replace the installed leds with rgb leds to get the color changing to work after adding in Forscan. I only had blue ice leds for the cup holders and rear seats when I added them to the Ranger Raptor and just went with that. The shifter and all other buttons are blue ice so I think it works.
Ford Ranger Ambiant lighting and driver seat IMG_0584
Ford Ranger Ambiant lighting and driver seat IMG_0585
Ford Ranger Ambiant lighting and driver seat IMG_0586
HyperM3
Lawrenceville, NJ
Awesome job!! What module was that in. We need to start putting together a sharable doc with the things we can make changes to.
Stumpm2
Wyoming
Nothing with Forscan. I physically added ambient cup holder and rear seat LEDs from other Ford vehicles added a wiring harness to connect into the light above the glove box.
HyperM3
Lawrenceville, NJ
No, I know what you did. My comment was for @jrRaptor, he was able to get into a module in forscan to access the ambient lighting color part on the infotainment screen. Regardless of not being able to actually change the color.
Stumpm2
Wyoming
Sorry, I thouht you quoted my reply. I believe the ambient lighting colors are in the APIM if I remember correctly. The color changing should work if you change the LEDs. This has been done on Super Duties I know.
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
SOLA Motorsports
Something like what the Bronco crowd did in this thread may be needed for us. Seeing as if those are 3 wire leads (aRGB), that gives me hope for a simple plug and play swap using similar hardware they dug up
Bronco Ambient Lighting
