Anyone fiberglass the back seat...
corysquires
Cory
AZ
IT
Has anyone attempted to fiberglass the under part of the back seat. And added with a 2" seat lift? How much free net air space were you able to achieve. I'm going to attempt this soon and need a solid .8CF Net for a Hertz MPS 300 S2 12. Any feedback would be appreciated.
Nope. None that i have seen or read of
some_guy
some
florida
entrepreneur
why do you want to do this? the rear seat head room isnt the greatest and you want to make it smaller for what reasoning?
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
I’m not understanding. Are you asking about a rear seat delete? Or something else?
Any mod like this will wreck the resale value of your truck, unless you remove it completely first. Make sure you do not permanently mess up the factory seat and mounts. I am pretty sure you won’t find any pre made kit because of the headroom issue…
Maybe you should explain why you don’t want to use one of the much easier behind the seat back setups.
Are you experienced with fiberglass layup and familiar with its serious health hazards?
Sharpie223
E.Wa
In-between atm
If I understand correctly, you are trying to raise the back seat by 2" to fit some audio gear? I don't know that you need fiberglass for that, but that's going to be very involved to retain a safe back seat. Do you actually need a back seat or would it be better to remove it for your uses?
sdca7718
VA
It’s been measured and it’s no where near .8, don’t think anything bigger than a 10” will fit under the seat.
TyGuy81
Ty
Seattle, WA
Woodworker
Get the Wavtech ThinPro 10. It only needs 9L and you can get that moulding the storage well and leave the seat as is. I’m running it now and seat bottom locks down and still sounds great
The Hertz MPS 250 S2 is more than capable of overwhelming the rest of the system and it fits. Like others have mentioned, why ruin the truck for an additional 2" and a few extra Hz?
ummagawd
Tommy
Huntington Beach
Stelvio Quadrifoglio
I was considering this sub, which enclosure are you using and how do you like it?
TyGuy81
Ty
Seattle, WA
Woodworker
I actually made my own. I used painters plastic in the recess and mixed some expanding foam for a cast then fiberglassed that. I wanted to have all that space to work with vs just the plastic to mold from. I have a second one in case you’re in the PNW. I love the Wavtech! When it finally broke in it was almost like a switch flipped. It was really good and then one day I realized it was great hahah.
ummagawd
Tommy
Huntington Beach
oh nice! I was considering fiberglassing my own to try and make as much available volume as possible... the area seems small enough to not be intimidating. How many cubes do you think you got?
TyGuy81
Ty
Seattle, WA
Woodworker
I got 9L, you may be able to squeeze out another L but having that lip along the front edge and door side I knew getting it in/out would be tricky. I think it’s the equivalent of like .3cu but a perfect fit for the Wavtech. Line it with painters plastic, get a 2 part expanding foam kit from amazon and pour it in there. You’ll need something to keep downward pressure though otherwise might end up with some voids. Sand it down a little, tape it off and fiberglass away!
This is what you have back there with everything removed.
I thought it would be interesting if someone built a tuned box and used that hole in the PS riser as the port exit. I'm not that person. Lol
