Bakflip MX4 tonneau - this much leak normal?
alrashid2
alrashid2
PA
Hey guys, got to looking a bit more and realized that, other than the bed rail leaks which are not the tonneau's fault, the right half of the first folding seam is also leaking... Water is dripping from somewhere at the folding seam on the bottom side, and the bed directly under that is also wet. I tested this in my usually parking spot which faces downhill but is level from left to right, and also parked flat. Definitely leaking from the seam.
Anyone seen this before? And is this something I can re-seal myself somehow? The drivers side of the seam stays dry, and all of the other seams are dry too.
@RealTruck sorry to keep calling you out again but wanted to get your take too. Thanks for the help all!
RealTruck
Ocala, FL
Ranger
Always glad to be of assistance!
The MX4 Gen 3 comes with an industry leading 5-year warranty. If you're ever having issues with your cover, we're here to help! I've DM'd you so that we can take a closer look.
alrashid2
alrashid2
PA
I've got an update to the water test! It is actually not leaking from the seams... but it is still unfortunately the tonneau cover.
I first covered all of the bed rail take pocket caps with plastic and taped down to minimize any leaks there so I could better decipher where the leaks were coming from.
The Sources:
1. Randomly leaking at the back two corners closest to the bulkhead (PHOTO 1). It was leaking from somewhere on the tonneau cover that I couldn't quite tell, then dripping onto the drain hoses and down those. That one I can honestly live with it since it's at the back corners where it should drain out the bed anyway...
2. Leaking between the rail and bed rail covers (PHOTO 2). This one shocked me but I was able to completely confirm it. There is a very thin foam gasket where the rails meet the bed, but apparently it isn't enough. It seemed most prevalent where the bed rail cannot fully be flush against the bed rail covers, as they have raised areas. The leaks were mostly coming from where there was a gap between the raised areas and the water was making it's way through the gap, and down into the bed behind the rails. Only thing I can think to do here is uninstall the rails, and find a thicker foam gasket tape to put onto the rail and compress that as I reinstall...
In the photo I tried to outline how it is leaking with a photo from the end of the rail. Just to be clear, it is NOT leaking at the end of the rail but across the entire rail at various sections. Photo just to help illustrate it.
3. Actually leaking past the rubber seal on the top of the rail where the rail meets the tonneau cover panel when closed (PHOTOs 3 and 4). This was the most shocking. If you look inside when the tonneau is shut, the panel does not sit tight at the hinges against that rubber seal. As a result, when a lot of water goes into the rail drains it seems to exit out this opening at each seal instead of staying sealed and moving down the drains. This is what made me originally think it was the seams themselves leaking when it actually is not: the water is just running out that hinge opening, hitting the seams and latches, and running down those. Unfortunately this one seems just like a design flaw rather than a defect in my cover specifically. Also seems like it would only be an issue during heavy rain when the drain rails can't keep up. Think like a small gutter during a big storm overflows: it's overflowing out the gap.
So that is where I'm at. Leak 1 (near bulkhead) seems minor and I can live with. Leak 2 (between bedrail covers) I may be able to fix myself if I can find the right foam gasket tape. But Leak 3 unfortunately seems inevitable.
I think my fix will be to focus on Leak 2 and uninstall the rails (again), get some proper foam gasket tape and seal where the rails meet the bed, and reinstall.
Ford Ranger Bakflip MX4 tonneau - this much leak normal? PXL_20260818_232309241
Ford Ranger Bakflip MX4 tonneau - this much leak normal? 1787098231113-2a
Ford Ranger Bakflip MX4 tonneau - this much leak normal? 93766-cf08013bc65bec4c17a207a6d5717667
Ford Ranger Bakflip MX4 tonneau - this much leak normal? 93765-3bec99f5b5dae60a926cf29c8bc58849
mattmico
Winston Salem, NC USA
‘24 Ford Ranger Lariat FX4
Self Employed
Hey guys. Have the Bakflip MX4 tonneau. Downpoured all day today. Checked today and got this much water in the back...
Looks like most of it is coming from the bed rail caps. But definitely some leaking at seams and such.
Im ok with it as it really is only leaking at the edges of the bed and draining along the side. Middle is dry.
Just wanted to make sure this was normal. Thanks all
I also have the same cover. I did not install the drain tubes and I get about the same amount of leakage as you’ve pictured from an automatic car wash.
alrashid2
alrashid2
PA
Update. We had a storm today so I decided to brave it and sit in the back with a flashlight and watch from under the tonneau...
Unfortunately it does look like the cover itself is actually leaking from the seams. I can't quite figure out how. But it's causing leaks in the middle of the bed, only at every interval where the seams are. The water is dripping through the seam and then down over the latch assemblies.
Hard to photograph but you can see a drip here and then the reflective shine of water running inside the seam here. Reaching out to Realtruck about it to hopefully get a warranty replacement of the cover and potentially try swapping the old and new covers and see if it solves the problem...
Ford Ranger Bakflip MX4 tonneau - this much leak normal? 1787248316056-6
Ford Ranger Bakflip MX4 tonneau - this much leak normal? 1787248332027-d4
some_guy
some
florida
entrepreneur
i despise that any leakage in any tonneau cover is accepted as "normal".
alrashid2
alrashid2
PA
Realtruck got back to me and is sending me a replacement cover to test out. Should be here in 1-2 weeks. We'll see!
Geo8866
2025 Ranger Lariat FX4
I said earlier in this thread that I have had three Bakflip covers and this is the only one that leaked. I leak in all the areas you pointed out too. I was able to mitigate the leaking in a few spots but I'm just going to live with it I guess.
alrashid2
alrashid2
PA
Wanted to give them a shot just in case. Luckily Realtruck isnt requiring me to drill holes and send a photo of the old cover until I install the new one and make sure it isnt worst !
Geo8866
It rained here last night and I got water on both sides. That's while parked; I never moved.
Ford Ranger Bakflip MX4 tonneau - this much leak normal? IMG_8423
Ford Ranger Bakflip MX4 tonneau - this much leak normal? IMG_8422
alrashid2
alrashid2
PA
I can deal with water on the sides. It's the water leaking from the seams dead center in the middle of the bed that bothers me.
The way I have my bed setup, I store water resistant things along the edge (cargo boxes, fishing gear, etc) but when traveling I'm putting luggage, backpacks, blankets, chairs, etc in the middle. I'm hoping the new cover won't leak and will stop those center leaks!
As for the leaks along the edge... I'm still going to pull the rails and add additional neoprene weatherstripping on the backs. I get a lot of water that leaks between the bed and rails, which I think is due to the thin, foam weatherstripping that come with the rails not being adequate.
I'm also going to try and use Duct Seal to somewhat seal the pocket seals from water.
I'll be sure to post about it all once it's done. Probably doing it all at once in 2 weeks or so.
Geo8866
My leakage is strictly on the sides.
gtyates
Greg
Goodlettsville
2019 Ranger Lariat 4x4, 2021 Explorer Limited 4x4
Manager
Any updates from our OP? Wondering if replacement cover was received and has been installed. Any difference in water intrusion? I will say I get that the issue is a combo of our factory bed rail covers and the MX4 not sealing well to it. That makes the most sense. I truly hate having any water in there. As I mentioned in my earlier post in this thread, my Bakflip soft folding cover on my '19 Ranger did not leak except a tiny amount in the car wash.
NOT_RAPTOR
Cleveland
So far my experience is in the rain it stays pretty dry back there from limited experience.
The touchless car wash let more water in, with that higher pressure spray from more angles. Didn't seem like too terrible of an amount.
