Coolant Intrusion issue on 24 2.3l?
Morningpride
Philadelphia
2024 Ranger LT STX
24 STX 2.3, 15k.
I have been experiencing morning cold start stumble/misfire. Just for laughs, I opened the hood to check the coolant (cold) and the reservoir was all the way down past the "min" measurement. Dealer topped it off and told me to "Keep an eye on it."
Please tell me this isn't happening. We went through this exact scenario with the 2.0l in our 17 escape. I can't find anything on the coolant issue on these newer 2.3 liter engines.
Anyone else experience anything like this?
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
24 STX 2.3, 15k.
Do an oil change and see how the oil looks and if you have water draining out of the pan. That will tell you pretty quick if you're losing coolant inside the engine vs an external leak somewhere.
Muffin1
Rob
NJ
Go over to sister site Ranger5G and search there,(same 2.3)
i thought i remember a thread about your issue, (I'll apologize now if I'm incorrectly remembering) lol
Morningpride
Philadelphia
2024 Ranger LT STX
No coolant in the oil, however the reservoir level is back down below minimum again.
Smell the exhaust. If it smells sweet, you are burning coolant. You can also buy a coolant test kit to check for combustion gas in the coolant.
Morningpride
Philadelphia
2024 Ranger LT STX
No exterior coolant leaks anywhere. The exhaust is a little smokey in the morning. Going to the dealer Monday so they can pressure test. ??‍♂
Morningpride
Philadelphia
2024 Ranger LT STX
*Update:
Dealer pressure tested Colling system and said the "EGR Cooler" was cracked. Since when to these little gas motors have an EGR Cooler??
Morningpride
Philadelphia
2024 Ranger LT STX
**Update Update:
Interestingly enough, when I got the truck home, the EGR cooler is bone dry.
Things that make you go hmmmmmmmmm?
