Covering frame tube holes
Geo8866
2025 Ranger Lariat FX4
I was bored and ordered these $11 frame tube hole covers on Amazon. Are the any issues with covering these holes that I should be aware of? Depending on which AI source you search, one said they are fine to cover especially if you live in an area that uses salt on roads and another said they will trap water and shouldn't be covered. Any opinions on them?
Ford Ranger Covering frame tube holes IMG_8369
OxygenMask
Phil
Eugene, Oregon
I've always felt that air circulation in places like that are less likely to cause rust.
Those types of things usually let moisture in, cause condensation, and are worse than leaving it alone.
Onceaneagle
Walter
2025 Ranger Lariat
US Army Retired
My Ranger is under coated and rust proofed. I put the covers on to keep gunk out.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
if you look in the tube, like I did on my 2025 xlt, theres a bunch of holes in the bottom of that cross tube. Once I get under coated, I might get a set just to keep majority of silt and fines of road salt out of it, but some is still gunna get in there.
Geo8866
Geo8866
That's my thinking. If there are drain holes, then the covers will be there to keep the solid stuff out.
Phoenix5454
Connecticut
2025 Ford Ranger XLT FX4 2.7TT
BMET
I put these on my Ranger because my 2014 F150 that I traded in had a similar tube across the top of the frame under the bed and it rotted out bad on the passenger side (probably from all the crud they put down here during the winter). I figured it couldn't hurt.
Loudpa
How about using the covers but say drill a small hole or two in them to allow air to circulate
I bought those as soon as I got the truck and installed them. I just want to keep junk from going in and maybe getting stuck, like rocks or something. Anyways, there are holes on top of that cross bar too, as well as underneath so Water will drain out easily. But, it also gets in easily because of the top holes
I ordered these covers, then common sense kicked in and I returned them.
And it looks ugly being able to see through the beam
Only if you focus your attention there.
I agree with the logic of post #2
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
This is my thought as well. Rust scares the **** out of me.
