Exhaust Tip
Sauce
Northeast
2025 Ranger XLT FX4
I bought this same one. Fit fine, looks good enough and no cutting.
I cut mine 3” or so because the original exhaust was very visible in the tip but probably just depends on how you position it. Looks good!
RichD
Rich
Washington state
I’m going to use some high heat black paint for the exposed tailpipe bend and the pipe inside the new tip
Aircraft examiner
you would be fine with regular flat black. its not hot enough to peel the paint at the back. it feels hot to your hand but its not going to cause any trouble for regular paint
mrjofus
Kevin
Fort Collins, CO
2025 Ranger Lariat FX4 2.7L
Received my MBRP tip yesterday and can confirm that it fits over the factory tip almost perfectly. I’ll post a pic after I have a chance to get it installed, i.e. when I have time to cut off the factory tube.
https://www.mbrp.com/products/t5196blk
Ford Ranger Exhaust Tip IMG_1139
Ford Ranger Exhaust Tip IMG_1138
Fawnbuster
Indiana
looks good, is that price on there site for a pair or single? anyone know if it fits the oem RR
Fawnbuster
Indiana
mrjofus
Kevin
Fort Collins, CO
That‘s the price for a single tip
Fawnbuster
Indiana
Will that fit a RR? I think because the top gets wider it wouldn’t fit over it. Could be wrong though
when i clicked the link it says it wont fit a 25
Kduane01
Kevin
Chester County PA.
Engineering
After a couple of misfits because our 2024 Ranger with 2.7 had an OD of 3 1/8 " tail pipe, bought this Ford Performance one from Summit Racing. M-5260-BCT1, about $150. Bought a cheaper MBRP one off Amazon for F150 years back but black finish started peeling off after 1 month. Perfect fit over tail pipe, i did cut off a few inches of tailpipe with saws-all since did not want to see the factory tail pipe and kept it back near the clamp. Real heavy duty and nice black chrome finish for a Cactus Gray Ranger. Easy 10 min install. Still looks new after 9 months.
mrjofus
Kevin
Fort Collins, CO
I just installed the MBRP tip and it fits great! I still need to trim off the OG tailpipe so that it's not so visible, but that'll keep until my exhaust pipe chain cutter from Amazon shows up.
Ford Ranger Exhaust Tip IMG_0929
Ford Ranger Exhaust Tip IMG_0930
Ford Ranger Exhaust Tip IMG_0931
Fawnbuster
Indiana
Just out of curiosity has anyone checked at there local exhaust shop and see if they can order them?
RichD
Rich
Washington state
I sprayed my exhaust flat black inside the tip. Barely visible now and if I want to go back to stock, there won’t be any issues.
Ford Ranger Exhaust Tip IMG_9649
