F150LEDs Order woes/grievances
NASSTY
ME
Well, install was worse than I had hoped, tapping into side marker not so bad but drilling through the grille was not cool. They are some big a$$ holes because of the connector part only, which seems silly… but they do look goooood (if I do say so myself)
I looked on youtube first and saw that it only took 5-10 minutes to remove the grill. So I removed the grill and drilled the large holes from the back side of the grill.
live_discover
Washington
Are the connectors not un pinnable? I just ordered a set and if i can just unpin the connecters and drill smaller holes for just the wire to pass through thats the route i will go.
mooner3
Michael
California
Yea they aren’t and it’s a huge miss on F150LEDs part. Holes could be tiny were it not for the connectors. As is, the drill bit you’ll need to use is basically the size of the entire space (if doing 3 lights) so it’s unnervingly tight. I did start with pilot holes and size up
fordgt
I got the 4 light kit from them but there was no way I was drilling 4 half inch holes in my virgin grill. I dropped them down a row and put them on with 3m tape. Been a year now with average 2 car washes per week. No issues.
Ford Ranger F150LEDs Order woes/grievances IMG_5691
Ford Ranger F150LEDs Order woes/grievances IMG_5687
Ford Ranger F150LEDs Order woes/grievances IMG_0079
RaptorPoke
Hmm, second guessing getting grill lights from them. No better sources?
Not that I can find. The other options all have an individual LED look, giving them a similar appearance to Ebay/Alibaba lights. The best fitment I’ve found is the moustas4d top grill replacement, but it too suffers from the individual LED look.
I believe supply and demand drives the F150LEDs price. When you’re the only company offering “raptor lights” that have a near OEM look/fit, you can set whatever price you want.
I plan on making my own side vent lighting for my RR since F150LEDs sells that kit for $139. If you watch the install video, you will see the kit is nothing more than a water-resistant LED strip with a positive and negative wire. I’ve ordered everything I need to make 10+ set for less than $20 using name brand LEDs.
I see lots of praise for the customer service at F150LEDs. They may be overpriced, but they stand behind their products. Their side marker light adaptor is neat, but I’d like to see it priced closer to $25.
My 2026 RR will hopefully be ready in February or March. I’m going to wait on the grill lights and hope a more affordable option with an OEM look/fit becomes available.
GLW
Missouri
If just a two wire harness I cut off all connectors, drill a hole just big enough to pass the wire through (without any connectors) and then use waterproof butt connectors to splice the wires back together. All you need is a heatgun or a lighter for the shrink/solder connectors.
jazpdx
jim
Portland
I wish I would have read this 1st. I was successful with 2 holes but the 3rd destroryed my grill 7/16 in a small blind space is a design flaw. A new knockoff grill is $350 bucks f150 AL ass does not know if cutting the connector voids the warrenty. Impossable to talk to a person. I am hoping to get some compensation. Why this thread did not show up when I searched F150LEDS is a question for the ruler of this forum.
Ford Ranger F150LEDs Order woes/grievances 17886304468563858541359087485265
landiscarrier
Landis
pocono mtns
sales
I have their grill lights and side vents lights. I’ve been happy with them from install to now. 🤷🏼‍♂️
jazpdx
jim
Portland
If you drilled them, then you were lucky and so was the video. At the same time they do look good but to add, the grill does remove easily and drill from behind. Go figure.
