First Oil Change at 500 miles
Yonder_MN
Joe
Minnesota
Following all of the other threads in this category and here is my data point.
Was a bit surprised with the comments from the oil analysis company, but wanted to share.
572 miles
Ford Ranger First Oil Change at 500 miles IMG_2403
wow. it seems a very positive choice to have done this at the 500 mile mark
Yonder_MN
Yonder_MN
Joe
Minnesota
I agree
Note the baseline in the report is for the next oil change (~5000miles)
Joe
burbansk
Bruce
Mio MI.
2015 Ford F150 FX4, 2024 Ford Ranger Lariat FX4
That is why I did my first one at 157 miles and our second at 2656 miles. After that it will now be every 5,000 miles. I like your choice in oil.
Ford Ranger First Oil Change at 500 miles 20250530_112133
vsliskovic
Vinko
PNW
2025 Ford Ranger XLT
sales
Hey there. Great info, thanks for sharing!
I’m at 873 miles in two weeks! I need to get my oil changed!
where do you take it and how do you get that report if you don’t mind me asking?
Yonder_MN
Yonder_MN
Joe
Minnesota
Since I use Amsoil products I ordered their test kits https://www.amsoil.com/search/#q=Test&t=totalProductsTab&sort=relevancy&numberOfResults=20
But there are several other companies that do the same thing. Blackstone is one of them and you can search the other threads to see what names they are. If your going to have someone change yours, take a small clean container (3 to 4 oz in size and ask them to capture a sample for you to send out
Hope this helps
-Joe
TractorFixer
Iowa
Thanks for sharing, it's always interesting to see and compare oil samples.
Further confirmation an early initial oil change is a good idea.
Although it does make me curious what 7,500 mile (from new) oil sample would look like.
Donnie B
Donnie
Woodland Park, Colorado
I read/saw somewhere that after an oil/filter change that the engine should be cranked over for about 10 seconds WITHOUT starting and running. To do this, push the accelerator pedal to the floor....step on the brake with the other foot.....then push the start button. Sure enough, the engine will turn over and not fire.
Just did my 500 mile oil change yesterday and that oil plug.........yeah........that oil plug is interesting.
Yonder_MN
Yonder_MN
Joe
Minnesota
Update 5000 miles 2nd change: The filter was dark, the oil was a light to mid brown, still could see through it, but glad I'm changing it. I'll see what the Horizon Oil Analysis says when they get the sample. 4500 on this filter.
Ford Ranger First Oil Change at 500 miles IMG_2834
Yonder_MN
Yonder_MN
Joe
Minnesota
Report from lab
Frank_MCN
Frank
England - UK
Ranger Wildtrak-X
Report from lab
Interesting, so on the whole - numbers have improved since the 500mi oil change. Good to see and validates the early change since there was a higher incident of fuel dilution in the early oil sample vs now. Thanks for posting this!
Yonder_MN
Yonder_MN
Joe
Minnesota
Changed again at 9100, found some metal bits in the filter. Will see what the oil analysis report says when that comes back!
Ford Ranger First Oil Change at 500 miles IMG_3437
Ford Ranger First Oil Change at 500 miles IMG_3438
Ford Ranger First Oil Change at 500 miles IMG_3439
Yonder_MN
Yonder_MN
Joe
Minnesota
So, now I have to learn a bit more about oil I guess! Here is the latest report at 9K miles.
- Joe
Ford Ranger First Oil Change at 500 miles IMG_0002
Yonder_MN
Yonder_MN
Joe
Minnesota
After a long, cold winter and too much idling, I'm sticking with the ~5K-mile oil change. This one is right at 4745, and though I could see through the oil stream with a flashlight, I think it was time. Will post the oil report once it returns from analysis. Good news this time, I could not find any shiny bits in the filter.
Ford Ranger First Oil Change at 500 miles IMG_3892
Ford Ranger First Oil Change at 500 miles IMG_3893
