Flowkottu on Amazon Retractable Hard Tonneau Cover
  • Thread starter Deleted member 8469
  • Start date
  • Watchers 19
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
Did you guys use the thick “waterproof sponge” or 2 layers of the thin along the top of the bed at the cab? The thick one seems like it might be too thick. The 2 thin ones look too thin. Seems like it might need 3 layers of the thin…
Just picked the thick one. Crossing my fingers.
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
Do these brackets look right?
They do not, but i can't say for sure. The way you can tell is to slide the bed side into the slot. The top face with the oblong hole should at lease be flush with the top of the plastic bed protector, as in the picture. If they are not, they will pull down on the cover from below, distorting it, as they are attached.
Also, the side screws with the plastic hats should reach the side of the bed when screwed in.
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
Thanks for your help. I requested the other brackets through Amazon. We'll see what happens. I guess I need to take the thing off my truck if I want to drive it. Ugh...
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
ihor1337
@RangerDangerStranger how did you contact them? I’ve had no response on Amazon so far.
I am not the one you asked, but I emailed them to the email address they have printed in the instruction manual. They replied the next day and then shipped the spacers for the brackets (see my post with the picture above) and updated longer screws. Once I installed them, the cover operated smoothly.
The only thing I noticed is that on the recent offroad trip I had to drive a couple of hours of washboards and the nuts became a bit loose, good thing I had the tools with me so it was a quick fix. I think some blue Loctite might be in order for those nuts.
SF Bay Area
Cool Dude
I didn't, i got the Brackets from Dsampson as he had gotten an extra set. Spacers work apparently with longer screws, only thing i might recommend is to epoxy the spacers to the top of the brackets. The less moving/sliding parts the better. CF
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
Wow. After contacting Flowkottu, they shipped me new brackets via UPS. UPS guy shows up at the house demanding $28 via check or money order payable to UPS or he won't leave the shipment. Sure hope these brackets fit. Apparently, this is due to the new tariffs against China.
ihor1337
Oh wow, that's kinda crazy. The brackets are free, so $0 x 140% tariff, should still be $0. Unless there's also a flat import fee on all items. Mine were delivered for free without any issues but it was also around a month ago I think.
SF Bay Area
Cool Dude
Sounds more like the Tariffs were on You. ?
Deleted member 9086
Most likely import customs duty on a large item.??
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
This wasn’t for the main tonneau cover shipment, it was a small box with new hardwear. Here’s the box:
Not that it matters. Just posting so other folks are aware, if they request updated hardware, they may have to pay the shipping company.
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
I’ve got it positioned and clamped down, but I’m having a lot of difficulty getting the drain tubes to fit into the holes in the bed walls. Wondering if I should look for some replacement tubing.
Upon more RTFM, it appears that you can route the rear drain tubes along the edge of the tailgate and hold them in place with the RTV silicone. See below. However, the passenger side looks like it will interfere with the tailgate dampener.
pdubizon
Parker
TX
Can anyone share pics of how far forward they have the cover mounted, relative to the front of the bed?
I picked a Flowkottu and thought I would give it a go with the included brackets(mistake).
I have requested the updated brackets, awaiting response from them.
LantaLurker
LantaLurker
Ranger raptor
I ordered the sadeloos off Amazon and the brackets didn't fit quite right. They said they are getting new brackets but when I reached out again they told me the cut some of the plastic along the bed rails(which I will not do)
