joordan
Italy
ranger wildtrak 2023
Ok played with I could as built and non as built. Enabled a bunch of useful stuff and removed a bunch of useless stuff
only thing I cannot get to work is camera at speed and 50/50 despite the settings being enabled
joordan
Italy
there is actually another one that does not work...trailer camera with turn...despite enabling it in non as built and then writing the correct value in as built, this value gets replaced by 0 every time I start the veichle, and thus the menu option remains greyed out. any clue?
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Which settings are you using to try and enable this? I've been meaning to try but have been too lazy to perform the daunting task of dragging my laptop out to the truck again :crazy:
joordan
Italy
the ones on the spreadsheet
CamerasTrailer Side View - shows corresponding camera view alongside of vehicle when turn signal is applied with trailer connectedunknown, use asbuilt (advanced)Not available - use asbuiltIPMA706-01-02*xxxxxxxxx--* -> Bits 1 and 2 (add 3 to enable both right and left. e.g. change 0 to 3)
If only left camera is desired, instead of adding 3, add 1, and if only right camera is desired, add 2
Turn Signal ViewsDisabled (Default), EnabledAPIM7D0-02-03xxxxx*xxxx--* -> Bit 4 (add 8 to enable. e.g. change 5 to D)
joordan
Italy
there is actually a thing I am not sure is correct on the spreadsheet. the note says bits 1 and 2...but the XXXX shows only bit 1 with *.....I changed that with 3, and after ignition it goes back to 0. should I change both bit 1 and 2 to 3?
rugedraw
Javier
Miami, FL
2021 Ford F150; 2023 Bronco Sport; 1991 Mustang 5.0 coupe.
Auto Sales
Not sure if the same applies to these trucks, but on the 21, 22 and early build 23 F150s, the IPMA needs to be updated before this feature can be enabled.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I was under the impression that the turn-signal camera view only worked in Towing mode. I was hoping you had a setting to enable it all the time
joordan
Italy
I haven’t tried plugging in a trailer or a load, but I forced towing mode and made my trailer active. That did not turn on the option. Maybe it requires an electrical connection to the trailer plug
But beside this feature, everything else worked and works perfectly. A pity the reverse tilt mirror does not do anything
rugedraw
Javier
Miami, FL
Auto Sales
Yea, it has to detect a trailer connected for it to work. However, if the bit that you change isn't sticking and it's changing it back, then maybe the event doesn't exist in the IPMA firmware. Pull the module details on the ipma to see what's strategy it's on. Maybe someone that has it working can check to see if the strategy in their ipma is different from yours to at least rule that out.
JJT
JAVIER
SPAIN
RAPTOR 3.0
I did enabled camera at speed though
Hi, could you please explain how you enabled the camera while driving? What settings or coding did you change? Thanks!
joordan
Italy
There used to not be a forscan way to turn of ass. I dont know when that was found but I am glad it was found
I am glad some one figured it out.
