Ragner
Victoria
2022 ranger XLT
Supervisor
Is it possible to enable rear camera view at speed? Guess it would be useful while towing.
Have anyone ever seen something about activating the front parking sensors? I'm going to try to activate and install it.
Also, I have some questions about the spreadsheet. What does those itens really do?
- Auto relock (Sync Menu): have no clue what this one does.
- Welcome lights (approach detection): I guess the car will turn on some lights when it finds the key nearby. Is that correct?
- Powerpoint timeout duration/configuration: I guess it has something to do with the power supply on 12V outlets. But what exactly does it do?
- Disable Auto Stop Start Feature (only affects cluster visibility/nag): it removes the start/stop icon from cluster, is that it?
Here is how I got my rear view camera to work at speed.
IPMA 706-02-02 xxxF CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 Axxx xxxx xx--
APIM 7D0-01-04 xxxx FCxx xx--
APIM 7D0-02-02 xxx3 xxxx xx--
Garaged
Usa
Ranger raptor 2024
Has anyone here successfully activated "Reverse Mirror Tilt"? I have it activated using Forscan. However, even though it shows up now in the settings, it doesn't actually do anything. Is there a particular sequence of steps to make the rear view side mirrors tilt downward when reversing after activation?
Is this still the correct procedure for fully turning on adaptive headlights? Any tips for how to use them, as in, do you need to have auto highbeams on, etc? Thanks.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot_20250108-182045_Edg
renato23
Renato
Brazil
Ranger Black 2.0
Thanks! I'm going to test it. How do you turn the camera on at speed? It appears a button at the car screen for you to click it or it has some other way to activate it?
I tried to do the camera one and it doesnt work on my truck. Wont let me save the value change in the ipma, it errors out
I just removed eco and normal mode on my truck. Should not have autostart stop anymore. We are about to see
Yup, it worked. I start in sport mode and auto start is off.
Ruh roh, now trouble. It starts in normal and no other trans modes are available. Back to the drawing board
Ok, verified multiple times, normal mode cannt be removed, even if you disable it.
I geuss the computer only see normal when it starts. If you turn the key to run, normal is moved to the bottom, instead od the top, and once you push the mode button once, normal disappears and is no longer available. The truck then acts like it has no normal mod till tou turn it off and on again, where it restarts in normal, till you push mode again.
Once you actually start the truck though, you can no longer pick any trans mode if you start the engine and normal is showing as the start setting.
If you Switch to sport, and then start the truck, you can chose any mode, and sport and eco are not available.
So normal is a default setting in the pcm or something and requires more work to remove.
I did turn off adsptive shift stratagies and it no linger skips secind gear, which is a plus
And i did the pcm relearn and everything and still nogo on the normal disable
CoryB
Cory
Virginia
I did turn off adaptive shift strategies and it no linger skips second gear, which is a plus
Details on how you did this please.
And thanks for all of the experimenting. I’m too chicken to try all of that.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
I'm having trouble writing on BdyCM Module in my friend's car. I have done it many times in my own car, but on his specific vehicle every time I try to write the you running
Finally coded this on Sunday and tested it on the way home from work last night. Worked amazing. It was so cool watching the lights turn on and off on the sides when cars were coming. Thanks again for posting this!
Followed this. Not sure if it’s working because it’s daytime. I had this on my bronco and i thought the “A” was green or blue (mines white)? That’s all I’m questioning now.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_0625
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_0626
renato23
Renato
Brazil
Ranger Black 2.0
Guess it only works on vehicles that have the 360º cameras. In my car, that only got the rear camera, there's no way to activate this camera without using the reverse gear.
And btw, nice testing sequence you got there. Great work.
How did you god rid of the adaptative shift strategies?
Raptortugal
Portugal
Ranger Raptor 6g
The white "A" is normal (that's how it is on my Raptor with the stock function).
The blue light will also light up next to it automatically.
renato23
Renato
Brazil
Ranger Black 2.0
Last friday I installed a trailer hitch in my car and found out that even though it didn't come from factory, it has the electrical plug hidden there in the rear.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745784547967-h2
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745784595396-i
Now I just need to buy the wiring harness and connect it.
Why I'm telling you guys all this? Because this got me wondering if that would be the case for the front parking sensors as well, as my car doesn't have them. Maybe I just need to buy the wiring and the sensors and install everything.
That's my new research field. lol
I already got the sensors and the wiring harness part numbers. But before buying it, I got into forscan to check if it would be possible to enable them. As it turns out, I found some things related to this in PCM, IPC and APIM modules. Enabled everything hoping I would get some kind of error message on my cluster telling me I had a problem with my front parking sensors. Got nothing. Put my car in reverse gear so maybe I would see the little waves that move and change color to indicate proximity in the rear factory system and also got nothing.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745785241277-hh
So I went googling on how to do it in other Ford vehicles and found some information on a F150 Forum and giving some instructions on how to do it. Thought that would solve my problem. I was able to do it all except the IPMA module ones, to change from 4CH parking sensors to 8CH. I can't find the IPMA module in my car. I'm not sure if it's something related to a software issue (forscan not recognizing this module) or a hardware issue (my car not having this module at all).
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot 2025-04-27 at 17.23.06
Anyway. Any ideas on what I should do next? I already have a front camera installed (you can find all the information on that clicking HERE!) but it would also be nice to have the parking sensors.
