Hande
Hannu
Estonia
Business Owner
I’m not entirely sure what you want.
Here’s how mine works currently with the code ive shared.
With either front passenger unbuckled, the dash seat icon lights up:
However, i just found out a rear seat passenger will not trigger the unbuckled warning.
I switched the my view over to seatbelts, and it does not know there’s a rear seat passenger.
However, when the rear passenger buckles up, it does show that:
Yes, the front seats light up red on the seatbelt screen with no passenger. I didn’t return the code to stock to test, but I’m not sure my truck detects rear passengers at all.
I don’t have kids, so not a concern for me. Best of luck figuring out a solution that works for you.
How do you make numerical temperature readings visible? Like 120F and 69F
SnyperX
Mark
2024 Ford Ranger XLT
Does anyone know if this will actually disable the start stop feature on the Ranger. Found this in the PSCM module:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1761927048998-fn
Hande
Hannu
Estonia
Business Owner
Does anyone know what is "Off-road tire pressure" in IPC module non-asbuilt, what does it do?
Nope, you will be the tester
sloon
Michal
ČeskÔ republika
Ford Ranger Raptor 3.0 V6, 2023
this is how I turned off the start stop on my Raptor 2023
Disable Auto Start-StopBdyCM726-48-02x*xx-xxxx-xxxx*=0
BMS ConfigurationBdyCMNON-ASBUILTBMS ConfigurationPWM
Auto Stop StartIPCNON-ASBUILTAuto Stop StartDisable
Battery Target State of Charge, %BdyCMNON-ASBUILTBattery Target State of Charge, %100%
Peter949
Peter
Irvine, CA
Someone want to try it NA Ranger? I might tried if I have time to play around with my laptop.
vgppdmtr
vasilis papadimitriou
greece
ranger 2024
There have been several threads about FORScan, but would like to consolidate into one place like was done for the 5G Ranger.
The below document will be updated as people give confirmation as to what works and what does not. I am hoping to find GUI changes as Asbuilt changes together if possible, like you will see on the Confirmed tab for the Chimes and Bambi mode
Web version: FORScan NA Ranger 6G
Actual Gsheet: FORScan NA Ranger 6G - Gsheet
The 3 most useful tabs:
  1. Features Confirmed - these are options that are proven to work on the Ranger
  2. Features TBD - these were collected from F150, Ranger5G, and Bronco and need to be confirmed
  3. FORScan GUI - this is a dump of all the options for all NON-ASBUILT module pages in FORScan while connected to a 6G Ranger
IF YOU CAN CONFIRM a configuration change works, if you could post to this thread with this information:
  • Feature name from the Feature Tab
  • What value you changed from -> to (asbuilt only, or GUI)
  • Ranger trim level tested on
  • Any side effects or gotchas when making the change
  • Any other details of what the feature actually does (in layman terms)
Please PM me if you would like to be an editor for this sheet or request access from within the Gsheet.
** NOTE ** The sheet may take some time for changes to get entered after there are posts with confirmations. So be patient please :)
vgppdmtr
greece
ranger 2024
Hello,im writing his email from greece , i have the 2024 ford ranger wildtrack , 2000cc diesel.I enabled the sport mode by forscan at the trial i did it never put the 10th gear , i reached 160 km.Did anyone have the same problem an if so is there something i can do to fix this? Sincearly Vasilis
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
I have wondered the same thing... I am keen to try it next time I head off-road as the way the TPMS works thus far when operating at reduced tyre pressures is nothing short of infuriating. Resetting your pressures results in no low pressure warnings for about 5 seconds before the stupid low pressure warning pops up again. As it is, TPMS is useless when off-roading with lowered pressures.
Hande
Hannu
Estonia
Business Owner
I think you can adjust TPMS pressures. "TPMS Placard value" in IPC non-asbuilt menu if I remember correctly...
limoss
Lee
Australia
Ford Everest V6 2023
Mine definitely has off road tpms as well as normal tpms, I will try it this week I can only assume it applies itself when you select an off road mode, will let you know how it goes.
renato23
Renato
Brazil
Ranger Black 2.0
Guys, any news on disabling the start/stop thing with just forscan? I was only able to do this using the 4Dtech hardware solution.
sloon
Michal
ČeskÔ republika
I gave instructions in a previous post. It works for me on a Raptor 2023
Hande
Hannu
Estonia
Business Owner
Is there a way to make boost gauge work in Next gen Ranger Raptor diesel?
I can make the gauge appear, but it is not doing anything :frown:
