RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Before coding? No.
After I got my 25 RR back from the trailer module recall I noticed I had a BCM code I could not clear and my switch to turn on the bed lights no longer worked. In the As built tab on the BCM at the bottom is return to stock. I clicked that and, with internet connected, it downloaded the stock BCM as built through forscan. Didn't thave to download anything as I didn't save or backup either. That cleared the code and the switch started working again. Went back and did any changes I needed and everything is working perfectly.
Ranger43931
Tacoma
Just drive around at night. Being behind somebody else or with traffic oncoming you will notice immediately.
I also figured out the anti-glare coding on the current generation M3-M4 before anybody else did. It works exactly the same, if not as precise as the laser headlamps on that model.
You are amazing, thanks for figuring this out.
BrrRaptor
Raleigh Nc.
Just tried to change the Powerpoint Feature to disabled to turn off the timeout session so the 12v plug in the bed would be on fulltime and now it has no power after key off? I previously had the Powerpoint time out increased to 1 hr and that worked perfect.
Can anyone that has tried this maybe chime in? It seems straight forward and not sure why it wouldn't work. I doubled checked that I saved it to disabled and tried starting the truck and then turn off.
GeneralPower Point Timeout ConfigurationPower Point FeatureDisabled (Always on), Enabled (use timeout - Default)BCM726-57-01xxxxx*xxxx--0 - disabled/always on, 1-enabled/use timeout duration above. 12v outlet power off (seconds) after AUX is off. Affects center console power port as well as the one in the truck bed, but not the USB ports or 120VAC
rvcamara
Raul Victor
CA
Has anyone figured out how to increase the brightness of the DRLs with the headlights on in Forscan?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1000335080
BrrRaptor
Raleigh Nc.
I figured out the problem. My battery was low and the battery saver was on causing it not to work. Once battery was charged it worked just fine. Both 12v outlets in the console and bed are constantly on.
I turned on that power distribution screen to see what it shows on a lowely 2wd stx.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 20260422_184743
It shows up. Its in the setting with the all the off road gauges so it gives you the option to toggle up to thr gauges, down to this, amd the oil life screen is one more down.
But, while driving, this shows nothing so its a waste to activate. Unless there is some other things you also activate that i missed?
landiscarrier
Landis
pocono mtns
sales
You can change the battery state of charge in Forscan too. I think it’s set at 80% from the factory.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Since it is still in the "TBD" tab, I wanted to confirm that the setting to enable the Turbo Boost gauge does work. It adds a boost-only gauge instead of the normal vacuum/boost gauge
The "standard" gauge:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet rraptor_vacboost_guag
The new Turbo Boost gauge option:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet rraptor_boost_guag
@craigc if you want to mod the spreadsheet, here is the requested info:
Feature Name: "Turbo boost gauge in cluster"
Value changed to: Used the non-asbuilt GUI menu, set to enabled
Ranger trim: Raptor (2026)
Side effects: None noticed
Other details: Same boost as the "standard" gauge, but cleaner looking
nice
2024raptor
Philippines
Has anyone been able to play with the 360 camera settings? I can see that there are a lot of settings in the spreadsheet such as 360 offset, camera shortcut etc. and maybe we could modify the 360 camera angles and even add a shortcut to the steering wheel.
RCMUSTANG
Ray
Los Angeles
Anybody activate 5 TPMS and add one to a spare? I'm considering picking up another full size wheel for the spare and rotate through all 5 K03's.
BTW, no one has updated the sheet that Lincoln auto folding mirror was confirmed by me a few weeks ago.
Someone has the spare activated. I cannot remember who though
jrRaptor
Maize, KS
For the 2024's I just picked up a new sensor since the spare doesn't have one. Got an OEM wheel to match the rest, put in the new sensor, and the truck will automatically read the wheel in place when you swap it out. I do 5 wheel rotations and can confirm they work easily without issue.
RCMUSTANG
Ray
Los Angeles
But did you activate it with forscan? I saw number of tpms somewhere when I was making changes. And do you know which frequency the sensor was?
EzequielArgentina
Ezequiel
Buenos Aires, Argentina
Ford Ranger T9 2024
Auditor
I had to replace one of my tires (back left) by the spare one (which is similar size and rim).. it was just replaced at the station and the truck recognized the new one automatically (it already had the sensor).. but I thought it would be detecting the old one.. and no.. it automatically detected the new one and no error at all.. The replaced one, just laid on the truck bed
