Installing an OEM wireless phone charger
Geo8866
2025 Ranger Lariat FX4
I have a 25 Lariat (2.3) and I was considering installing an OEM wireless phone charger. The part itself is only $83. My concern is the installation. It looks like you only have to pry off a plastic cover in the console area and put the charger in its place. Does anyone know if this is just plug and play or does installation require additional wiring? A link to the part is below.
https://www.fordoempartsoutlet.com/...A83f-kHytYWhD7DVIqd92k7X8_Sc2NGUaAq9EEALw_wcB
Intercontinental_Ranger
Cambridge
2025 Ford Ranger XLT FX4
Crisis Cowboy
The wireless charger is more of a phone warmer in my vehicle - I don’t use it unless I’m desperate.
I have an otter box case on my phone and I think it makes it too far away from the wireless charging antenna, hence the heating.
Other people have had similar experiences, just wanted to make sure you knew that might be an issue.
Geo8866
Geo8866
Thanks for the info. I also have an otter box. I had a wireless charger in my last two vehicles. One worked great and one did exactly as you described. I guess I will stick with plug in.
mp51998
Thailand
2025 Raptor Ranger
Even with my phone bare it still gets hot.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Yup… OE charger is a phone cooker
I needed something so I ended up putting in a chilled MagSafe charger
Ford Ranger Installing an OEM wireless phone charger rraptor_console_wire_routing_4
It uses a fan and Peltier element (thermoelectric cooler) to actively cool the back of the phone while it is charging. Keeps the temps down significantly, but the phone still gets warm except right where the charger touches. Then it is cold to the touch
bigb
Tucson
2025 Ranger 2.7
Magsafe copy here, with my Android phone and Magsafe copy case the charge level is just right and I don't get a lot of heat. More of a maintaining charge than a recharge.
(I used a side mount console insert from Digital Twin)
Ford Ranger Installing an OEM wireless phone charger 20260213_160413
Ford Ranger Installing an OEM wireless phone charger 20260213_160333
AugPal
Augie
Chicago
Retired IBEW
My Ranger came with the OEM Wireless phone charger. At first the phone would get too hot so I wouldn't use it. After a couple of software updates it seems to be fine now and I use it on trips.
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
I have a Samsung in an Otterbox. The wireless charger works perfectly for me. It charges well and the phone doesn't get even warm.
Do what you think, but that's my experience.
I can't say whether software updates have fixed old problems or not, but my wireless charger works fine, as do the wireless chargers of other Ford owners I interact with daily. My family has a mix of iphone models that all work fine; coworkers and friends are a mix of iphone and android users. The only "complaint" I hear is that it charges slowly, which I agree with, but at least when I use a navigation app through my phone for an hours-long trip my phone is more charged at the end than the start.
Geo8866
Geo8866
Then back to my original question: Is the charger plug-and-play or does it require wiring?
Reddog99
So. Cal.
2024 XLT Ranger FX4 2.7
You have a Lariat and it didn't, come with the wireless charger??? I have an XLT with it...
But if you don't already have one, I would recommend something OTHER than the Ford charger. It's VERY picky about phone placement. If the phone isn't in just the right place, it won't charge and it's hard to tell when it's actually working.
And if you're using something like a map app, then the charging rate can barely keep up with the discharge rate. I ended up just using a USB-C cable. It's foolproof.
tamitchener
upland IN
2024 Ranger Lariat
don't waste your time, everytime it moves on the charger it kicks the screen on ,on mine
Geo8866
Geo8866
Nope, mine did not come with the convenience package. I plug in and it charges just fine. I just got used to dropping my phone without plugging in with my last car. If it were a plug and play feature, for $83, I would get it and take it out if it didn't work well
emjay24l
SW-VA
2024 Ranger Lariat FX-4
DEADDACK_33
I can't help you with whether or not the OEM wireless charger is a plug & play install or not. I just thought I'd chime in with my .02 cents regarding its charging capabilities.
Straightaway, it's not bad. It gets the job done. It's definitely flawed though. Your phone can get quite hot. Too hot IMO. Your phone needs to be placed perfectly for the charging to work, and it moves even just a tiny bit, it'll stop charging. Lastly, I find it to be in an awkward location, especially when the shifter is in Park. I'd prefer if it had a horizontal orientation instead of a vertical location.
My Ranger came equipped with the wireless charger, and to keep my phone (S24 Ultra) from getting too hot, I turned off fast wireless charging. The downside is obviously it's a trickle charge, but at least it keeps the temperature within an acceptable range. I recently got a new case (Otterbox Defender Pro) and its bulkiness is actually beneficial because now, my phone fits tightly onto the wireless charger. That keeps it from sliding off the sweet spot and keeps the charging from being interrupted. No fix for the location though.
So, if your heart is set on the OEM and it is plug & play, it's probably worth it for a clean setup and no extra cables. If you're open to just getting a wireless charger, it's probably worth exploring other options as there are lots out there. Whatever you decide, best of luck, and be sure to update us!
