Instrument Panel Defaults To Factory Settings. Getting Sick Of It
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
So far the only time my ‘26 has reset is when doing an update in FORScan that resets certain modules. But that is expected
OxygenMask
Phil
Eugene, Oregon
Mine does that about once a day.
Radio also likes to switch from Sirius to Pandora thru Android Auto, on its own. And it persists after I switch it back a few times.
ColeTrainsRR
Cole
Minnesota
E-Tec 3
mine will randomly kick out of MyView and into one of the other tabs, usually Trip. Sometimes mine switches into the Calm tab. Seems to do that mostly in the a.m. or evenings though. Maybe because its dark out?
boraxman
Santa Clarita, Ca. USA
2024 Raptor, I have had:
Reverse camera come on while driving forward.
SYNC Screen totally blank out.
Switch drive modes.
Switch user dash gauges.
4D Start/Stop eliminator overridden (thought this was very strange as it happened randomly at a stop light well into my drive).
Funny part is most all of these have only happened exactly once with the dash gauges a couple of times.
I'm fairly convinced this is a weak battery issue. I went to the dealer to have my battery checked out and they told a rest voltage of 12v is normal. I don't buy it, but truck keeps starting up...
jrRaptor
Maize, KS
I also have this issue. Happens fairly often, I have to go in and reset MyView to all the gauges I want to see. It's annoying but I've never tried troubleshooting the issue or looking for commonalities.
I have:
  • Ford Performance Tune
  • Dash cam with parking mode
  • Experienced the ghost-mode shifting
  • Auto updates enabled
  • Use both key fobs
  • Get several engine light codes randomly (EVAP related)
I am also leaning towards a low battery charge issue, mine gets low, likely because of the dash cam at times.
RaptorDJD
D
South FL
2025 Ranger Raptor, 2014 Frontier Pro4X
All I can say it that I keep my truck on a trickle charger so I don't think it is a battery or power thing. It looks as if F150 Raptors have had this problem since early 2021. I am thinking software bug. Being it is 2026 and the problem has been around since 2021 on the F150 Raptor, I won't hold my breath on a software fix. Just saying..
jrRaptor
Maize, KS
Forgot to add, I also put mine on a trickle charger, but only if I know the truck is going to sit for a while or if the weather is cold. I haven't paid attention to MyView while it's on the charger so I'll have to do that.
My default view is tire pressure with tire temps.
Redun
Oxford, UK
Tyre temps? How do you do that?
