J-Braces
FreezingFlatlander
Montana
2021 Ford F150 4x4 3.5 Ecoboost
Ford Ranger J-Braces IMG_6540
The J-Braces to stiffen the front corners of the box are some pretty substantial pieces of iron, am guessing they weigh 3 to 4 lbs each. After reading the instructions it looks like this is not going to be an easy project. Installing the J-Braces themselves shouldn't be hard but removing the wheel well liners and reinstalling looks to be the hardest part as it requires a rivetnut tool and drilling out rivets. Am going to do it but not looking forward to it. The Lariat has not arrived yet, it's on the rail somewhere.
jrRaptor
Maize, KS
I need to order some. Please let us know how the install goes.
rwolfcastle
How much does the dealer charge for install?
Cyrusblack
Banned
Banned
Pasco County
On the ford Accessory website, I believe there is a box you can check to have the dealer labor included with your purchase. I believe if memory serves it said extra $192.00 for the labor option.
LoneStarCaviar
Bear
Self Employed
That sounds 100% worth not having to do it myself.
Only if you trust the techs at your dealership. I will personally be doing any install on my own truck myself. Granted I do own my own personal shops with lifts and probably have more tools that they have at my local Ford dealer. Still $200 seems inexpensive if they have to drill out rivets. Looking forward to seeing it done first on someone else’s truck lol.
I don't understand why this part isn't included from the get go.
Been wondering the same thing.
After all it is a truck , it has a truck bed and most likely will need to do truck stuff With said truck bed.
Totally 100% agree it’s total BS that I am going to need to spend an extra $400 bucks to reinforce the truck bed so I can use my crossover style toolbox and headache rack on my new truck.
I can say I did not have to that on either of my last chevy Colorado’s .
Ford Ranger J-Braces img_3552-
Ford Ranger J-Braces img_4026-
jedadiah
Jed
Kentucky
'24 Ranger XLT 4x2
I'd like to see a spec sheet from Ford that sates when these are needed. Do I need it for a crossover toolbox? A retractable bedcover?
The install doesn't look terrible. Drilling the rivets out is easy, but I wonder what size rivet tool is needed for the replacements. I'm sure it's bigger than the little one I own, so this install will either require me to pay someone, or purchase a new tool.
sikedsyko
24 RRaptor, 05 Z4
The listing for the J-Braces says
"When installing accessories extending above the load box side rail and weighing more than 88lb (40kg) must have load box reinforcement brackets installed"
Which is pretty damn pathetic. I'd be over that with a set of overbed rails and my kayak.
Yep, 88lbs above the rails.
My rack and my toolbox empty pretty much have that covered.
‘With tools and jacks and such my setup comes in around 300ish pounds.
The rack alone is around 100lbs.
What I don’t know is if since my rack is all welded one piece rack rails with angle iron, would that in itself take care of the structural issue. I would really like to get a better understanding of exactly what these braces are intended to reinforce, what exactly happens without them?
DanTheMan
Dan
Escape
Social Worker
Sounds like an engineering fail Ford. Brutal. So can I safely sit on the side of my truck bed? That puts me 112lbs over the limit.
