White willy
Earth
2025 Ranger
So,how are you getting the brake lights to work?
Rclancy1023
Robert
Rhode Island, USA
2025 Ford Raptor Ranger
Security
Nope, returned them to Ford. Putco ( manufacturer) told me they do not support the model Ford is selling and at this time, they do not have one for the 2025 Ranger Raptor.
Joe T
Joe
Chicago, Illinois
@ntbruncie,
Thanks so much for sharing the wiring diagrams for the lightbar install. Can you please post a picture or explain where on the vehicle you hard wired the light bar harness. I have tried to hard wire in front of the hitch connector but it still registered as having a trailer attached. Thanks.
ntbruncie
ntbruncie
Nick
Phoenix Arizona
@ntbruncie,
Look at the outsides of the hitch, on each side you will find the harness and a plug. They are directly under where the tail lights sit.
Jetsss
Kevin
Connecticut
2024 Ranger XL
No, the access hole to lover the spare is next to the license plate.
Thanks for the post, the lights look aweseome. I love the letter on the tailgate..was that difficult to put on? If you don't like it, is it easy to take off? Thanks.
the tailgate letters are very easy to put on but i am not sure how easy to take off. they are stickers with good adhesive on them
fordgt
Where did you tap into the harness, at the end where you can see the colored wires going into the plug? Or did you unwrap the harness somewhere in the middle?
fordgt
Worked on this for a couple hours today, tapped into the backup and left turn signal successfully. The right turn is acting strange. Instead of flashing amber, the center 2 sections are flashing red. No brakes or running lights so far.
fordgt
That is where I am tappin, I peeled about 5” of tape back.
Neil S
Neil
2025 Ranger Lariat FX4, 2005 Ford Explorer Sport-Trac XLT 4x4
EHS Manager
I used an XKGlow on my 25' Lariat. My custom shop said it did not need a signal isolator like my 19" Lariat did but, it needed to be hardwired to keep all the warnings from lighting up/ringing.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
You can run a wire up to the BCM, per the ford Body builder guide. you tap the 3rd brake signal wire off the bcm. I did thhis for my cap brake and my Diode Dynamics C1R's. just had to take the brake module off the c1r 7pin harness, and cut the trailer turn/stop wires off thr module. and instead wire them into the new brake wire I ran, ground, marker and reverse still come from the trailer plug. and got rid my trailer turn signal errors.
there are also 3 blunt cut behind deiver kick plate. pos light(marker) high beam, and run/start(ignition) my labeled high beam wire was actually my marker. and my labeled pos light(marker)wire was actually my highbeam. lol the run/start wire is powered off the #92 accessory fuse in fusebox, so before I knew about it, I just used a fuse tap on that fuse. but now I can eliminate that tap aswell.
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) Screenshot_20250728_002748_Adobe Acrobat
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) Screenshot_20250820_102240_Adobe Acrobat
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) 20250822_150423
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) 20250822_150448
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) 20250822_092233
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) 20250822_092217
fordgt
I did this job this weekend, not too difficult. Thanks very much to Nick (ntbruncie) for posting this. He also answered some questions I had.
I will add my thoughts here.
When you order from Amazon you need to order the connector kit that has a standard 4 wire trailer plug and the crimp connectors (about $12).
Don’t buy the magnetic attachment kit, the area where it attached is hard plastic so you have to use the 3m tape already on the unit. I would recommend a good wipe down with denatured alcohol and getting some 3m adhesion promoter (either the individual pads or the jar which is a much cheaper alternative).
