Mirror assembly - 2026s don’t have side mirror turn indicators
ballplayer
ballplayer
Deeshawn
Boston Ma
True, and I really appreciated that feature up until winter hit, the mirrors froze in the retracted position and it took a half hour of warm up and driving before they reluctantly unfolded. Turned the auto fold feature off after that. Now I just hit the remote lock and see the flash.
Welp thats no longer a option on 26 models since they removed the Blinkers ahah
BC_Blue
Dan
British Columbia, Canada
2024 XLT FX4
I had a 2014 XL F150 for a work truck, the dual glass tow mirrors were ported to a vent on the side of the dash, just a little foam gasket when the door was closed. Windshield defrost = side mirror defrost.
It also had crank windows. I don't miss that truck
ballplayer
ballplayer
Deeshawn
Boston Ma
pop the small triangle shapped cover off the door inside behind the mirror. look at your truck side plug, then look in my thread and see if the wiring diagram matchs. my 25 xlt was prewired to the mirror plug on the truck for heat, turn, puddle. was already power fold and bliss. no camera. if I want the 301a package xlt mirrors(heat, turn, puddle, bliss, power fold no camera) its 1400 for one side, and 1600 for the other side. I ordered the heated glass, and ran my own wires to the glass, and added wires for turns and puddle.
unless you add after market turns like say 3/4" button lights, there is no way to add the orm turns, as the housings are different. but if truck is pre wired still you can add your own, then enable them in forscan in each door module. also gunna get a set of amazon puddle lights and cut the hole for them in the bottom. thats what I plan on doing untill I either find a set of junkyard xlt 301a mirrors or buy the clearview towing mirrors.
https://www.ranger6g.com/forum/threads/adding-heated-mirrors-to-xlt.27183/
I finally got my hands on my new RR and pulled the mirror cap off. It seem the mirrors are Pre-wired for the turn signal (pin 10, stole your picture).
This makes me believe that all I would potentially require now is the lower exterior mirror cover, turn indicators, wiring in lower cover of indicator, light for indicator (assuming it’s not in the assembly). Then to Forescan to have the blinkers activate.
Ford Ranger Mirror assembly - 2026s don’t have side mirror turn indicators IMG_6810
Ford Ranger Mirror assembly - 2026s don’t have side mirror turn indicators IMG_6822
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
You have to get the whole assembly. The only parts sepperate are the ones here, not on the main assembly. but a set of 24/25 lariat/RR mirrors will bolt right on. then go in the driver and passenger door modules to enable the turns.
Ford Ranger Mirror assembly - 2026s don’t have side mirror turn indicators Screenshot_20260404_031757_Samsung Internet
GraniteRR
Robert
With the removal of the mirror signals, are the puddle lamps/zone lighting lamps gone as well? Do 2026 RR models still have zone lighting?
ballplayer
ballplayer
Deeshawn
Boston Ma
I still have zone lighting and puddle lights, power fold, and heated. For the price of the truck, I feel it's missing auto-dimming and the turn blinker.
GraniteRR
Robert
Thanks! That’s great the rest of the features are still there. Sucks on the signals though.
sdca7718
VA
So after install does anyone know where on forscan they get enabled? Also wondering if the ROW mirrors have the heater or if it will have to be swapped over.
some_guy
some
florida
entrepreneur
I assumed he meant this cubby-
Would rather not have that and instead make the console bigger...
Well.... that is the empty space where the non North American rear HVAC vents are. That is already a deletion.
Grabber
NJ
2025 Ranger Raptor, 2020 Super Duty Tremor & 2009 GT500
If Ford keeps decontenting the way they are going you will be lucky to get an engine and wheels. Its a shame they are really screwing with their customers, charge more, get less, and built like crap (Especially fit/finish). Unfortunately it has turned into the American way.
Personally I feel Ford has lost their way and with this strategy, it will come back to bite them at some point. However, these car manufactures operate on a strategy that they are to big to fail. They all know if they mess up too bad, the government (AKA tax payer) will bail them out.
$Bill
Bill
Northern NV
Shoutout to everyone who got a 2024 for the most robust features for this gen Raptor. They just keep deleting things every year.
I’m beginning to look at trucks - new and used. What else makes the ‘24s good?
I like the signals on the mirrors.
24 has +12V in the bed, the lariat trims have active park assist and electronic shifter which goes into park automatically as does the raptor
https://www.ranger6g.com/forum/threads/2-versions-of-gear-selector.15663/
25 only the raptor has the eshifter (auto park?) and only AC in the bed but still has the turn signals on the mirror with the right trim or options
for a small fee you cn get the +12V outlet in the bed as the wiring is there for it in the 25, likely the 26 too?
The lariat for 2026 seem to have the most decontent, headlights, side mirror turn signals.
The 2026 XL get the FX4 option which is sort of nice but you have to get the steel wheels it seems but not so bad if you want to get new rims and tires anyway
one sort of big upgrade from the 2024 to the later models is the 2.3L engine. The 2.7 and 3.0 liter has remained the same.
$Bill
Bill
Northern NV
Thanks for the info! I should have mentioned that I'm looking at/for RRs. New or used - but Chat didn't say they were any differences.
Good to know!
