New Oil Drain Plug looks different.
chasc
Illinois
2024 Ranger
I don't mind that it is plastic, the problem is that the oil gushes out when you remove the plug.
That’s why I’m quite curious about this new design: I’m wondering if that thin gap across the threads leading up to a hole is intended to allow oil to flow at a more controlled rate when you have the plug part-way removed??
AugPal
Augie
Chicago
Retired IBEW
I can't believe Ford went with a plastic drain plug. Is the oil pan plastic too?
Addendum
: I googled the oil pan
No, the 2024 Ford Ranger does not have a plastic oil pan
; it has a steel one. While Ford has used plastic engine oil pans on some engines in the past, the 2024 Ranger is manufactured with a steel oil pan
its fig
Fig
Usa
2024 ranger raptor
Addendum: I googled the oil pan
Oh buddy, I have bad news for you, I dont know anything about the diesels or the 2.3 but the 2.7 and 3.0 both have plastic oil pans, engine and trans at that
For over a 100 years everyone used a metal bolt Now plastic that is dangerously stupid
And for over 99 years people have been stripping threads in oil pans because the plugs are harder than the pan. Then came composite pans which are softer and more brittle than aluminum.
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
The people stripping oil pan drain bolts should not change the oil
embedded rock
Earth
One truck, two motorcycles
That would be nice to control the oil flow. If not, I'll have a piece of hose ready to hold up to the drain hole. First oil change for the RR is coming soon.
MasterCylinder
Jay
Retired, FF, CET, Mechanic
I ordered a drain plug from ford parts for the ranger raptor. The new one (o the right) looks different, it’s got two o rings instead of just one and it’s just longer in general. I haven’t had the chance to install it yet because I didn’t change the oil yet. But it is supposed to replace the old one.
On the website, it lists it as compatible with the 3.0 V6 among other engines. The image on the product page is literally the old one.
So I’m guessing this is a revision and supposed to be an improvement over the old one.
What are your thoughts on this? The part number is ML3Z-6730-B.
It's been updated because of Ford receiving reports on previous plastic type oil pans and drain plugs leaking. Years ago they also update other type of connection issues with dual o-ring instead of a single, Ex. on some transmission cooler lines, AC lines etc.... Strange they would try single o-rings in the first place from previous experience! Yet the 2.3l is still the good old fashion metal one! Note the slot and the hole, suppose to aid in controlling the out flow!?!?
BDMEM
Joe
Pickwick/Mississippi
2024 Ranger Raptor/ 2025 Explorer ST
Fedex/Retired Mx
That's why I went with UPR Drain Plug/set it and forget It on Raptor & Explorer ST.
Price is one time never again.
Jc
Ford Ranger New Oil Drain Plug looks different. 1765260854244-om
TurboRanger
Jack
Oakley , Comifornia
I bought one of those Never used it That thing would take and hour to drain especially if oil is cold
embedded rock
Earth
Picked up a spare drain plug as the first oil change is happening this week. Since I was at the local Ford dealer, I used some points for a engine air and oil filters and a cabin filter.
Ford Ranger New Oil Drain Plug looks different. IMG_20251209_112002259
Jc
I just bought this same one for my next oil change! Jinx. Not so much due to cost of not replacing a factory one every 2-3 changes, but the mess! The oil just pours all over the wiring harness and makes a big mess. Gets all over my hands too because the drain opening is much larger than an M12 bolt style, so it drains fast!
They probably did that to facilitate faster oil changes to milk more money from the service side (charge the same amount but pay less labor hours to the techs waiting for the slower drain). For me, I'd rather have convenience and low mess, so UPR it is!
rpkranger
rob
nj
2025 ranger raptor
drain plug was the same this was my break in oil change at 1000 miles wasn’t as bad as I expected wrapped the harness with aluminum foil and just loosen the plug and just let it drain 7 quarts came out
Ford Ranger New Oil Drain Plug looks different. IMG_7600
Ford Ranger New Oil Drain Plug looks different. IMG_7612
Ford Ranger New Oil Drain Plug looks different. IMG_7598
Ford Ranger New Oil Drain Plug looks different. IMG_7602
80238
Hopefully they don’t warp like the F150 plastic pans do - $3000 repair at the dealer.
that why my buddy said to make sure and get a 2020 or newer raptor (i think it was 2020 because we were looking at 19 raptor and stopped looking at it after he told me about that)
