Passenger side windshield wiper isn't going back down
Stryder
Richard
Minnesota
2024 Ranger XLT Sport 4x4
As the title says, after I turn off my wipers the one on the passenger side isn't returning back to its normal position. It stays up a little too high- high enough that I can see a good portion of it from inside the cab. When using it on a constant wipe it doesn't go down as low as it should as well. This is a recent development, as it was working fine previously. I was wondering if anybody else has experienced this? I tried to pop off the wiper arms to reset the motors but they're on pretty well and I felt like I might break something. I'd really like to resolve this without a trip to the dealer.
I've seen it. Sometimes it's fine, others it parks high. Probably one notch off on the spindle.
Mine does it too, sometimes parked in right position sometimes up a bit.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this wiper concern? Thank you!
Bonder
Manitoba
Are you sure they aren't in rain sensing mode? When they are, they don't park, they go to a state of readiness for the next raindrop. After a while of not sensing any, they will go back and park. But I found if I turn my truck off in that state they don't park, they stay partially up.
Can't recall the last gen doing that, but I turned off rain sensing pretty quickly on it.
Stryder
Richard
Minnesota
My truck doesn't have that feature. I've now noticed that they are sometimes staying too high, and other times going too low. The driver's side will actually go over the cowl sometimes.
yoopercharged
I'd check to make sure the arms are completely seated and if that's not your issue bring it into the dealer. Could be a linkage issue I suppose.
Stryder
Richard
Minnesota
I checked the nuts and they're tight enough. I have an appointment scheduled. Thanks.
alrashid2
PA
Any update?
chasc
Illinois
2024 Ranger
I can’t confirm if it’s a feature of the Ranger, but some vehicles I’ve had intentionally shift the wipers’ resting position so they’re not constantly bent the same direction, presumably to increase useful life. I’d guess something like that before assuming a mechanical issue.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I believe this is normal behavior. If the wiper is "working" it stays high. If the auto-sense hasn't detected water in 10 or 15 seconds (maybe? never timed it) it drops back down.
I do find it a bit annoying when I go to wash the windshield that I need to pull them up and THEN flip them up. But I'm getting used to it
Stryder
Richard
Minnesota
The service tech said it can be attributed to the dryness of the windshield. I never notice it anymore.
It’s been posted several times that this is the wrong way to do it. In the manual it states to turn the ignition on, engage the wipers, and when they’re high in their arc shut off the ignition; it’s now safe to pull the blades away from the windshield. Forcing them up from resting position can cause damage.
