Ranger RAPTOR V6 FORScan spreadsheet?
HyperM3
Lawrenceville, NJ
Any chance you've tried to activate the Matrix headlights yet?
I have not. I don't think we have the capacity to activate that in the US.
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
SOLA Motorsports
Interesting, from what I understand the F150 guys were able to get it activated in the US but that's comparing apples to oranges. It wasn't a small amount of coding that needed to happen for them, so its probably nice and buried for us, assuming the adaptations are in there at all
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
I have the matrix headlights enabled from factory (Australia). Is there anything I can do to help you guys get yours working - like share a configuration file or something?
HyperM3
Lawrenceville, NJ
I dont know if its just coding or if you have completely different hardware or modules.
Appleman1le
Eddie
Long Island
24 Raptor
in for results, hoping for matrix headlights and auto lock when walking away!
toddiscdn
Todd
Blue Point, Ontario, Canada
2019 Ranger Lariat 4X4
I got rid of the chime with key in, door open etc, but havent experimented any further. Would like to do Nav. on the fly like I did in my 2019 as well.
FullSend
Ninjaneer
I am able to sync up the vehicle to the forscan software just fine, and I backed up all the original modules. But once I started to make tweaks and write them in, I keep getting "service procedure interrupted" error. I tried multiple different ones and only try to make one change at a time. Anyone have this issue? I just downloaded the windows forscan version today so should have the latest version. I do have the free version, which worked fine on my Gen2, but is that the issue? Do you need the extended license or have you all been making changes with the free?
FullSend
Ninjaneer
Messing with this some more, it looks like mainly the IPC modules that lead to the error but I could edit the other modules (BdyCM and APIM) just fine. Trying to disable the seatbelt chimes. So not sure if it's an issue due to the free trial, or if it's just not an option.
jrRaptor
Maize, KS
No issues here. I use the free license (windows), just have to renew occasionally. I got rid of my seatbelt chimes without issue. I don't remember off hand which module it was, IPC maybe.
HyperM3
Lawrenceville, NJ
Im using the 2 month free trial version. Can you please take a picture of the modules you can access? IPC module doesnt show up for me when I load everything up.
FullSend
Ninjaneer
IPC Module at end of list, have to scroll down.
Snapshot of the error I keep getting. IPC module the only one that it occurs in. Not sure what else to try.
Ford Ranger Ranger RAPTOR V6 FORScan spreadsheet? IPC
Ford Ranger Ranger RAPTOR V6 FORScan spreadsheet? service interupted
HyperM3
Lawrenceville, NJ
Damn, wonder why I cant see it in my version. What OBDII connector are you using?
FullSend
Ninjaneer
OBD Link MX and MX+. Trying to see if either would edit the IPC but same result with both.
HyperM3
Lawrenceville, NJ
I got the cable the other day and was able to get into the IPC modules and make the changes to get rid of the seatbelt screen on startup. Thank god.....
