RCMUSTANG's Magnetic FX4
Trey1940
Trey
Martha's Vineyard, MA
2016 Fiesta ST, 2019 Ranger Lariat FX4 Sport
Confirmed - I had to write all the values in order for it to take, but the only change was 5553 from 5753. I now have the "US" radio format and US format speed signs again. I did find out this is definitely the "navigation in motion" change - when it was swapped I was able to search for a navigation destination while moving.
Little update: I copied your configuration and while the climate button was on the screen, none of the buttons on it worked. Also my TCS Off button stopped working, diff wouldn't lock, vents only blew defrost, etc, so I changed it back and looked at the F-150 spreadsheet to narrow down exactly what needed to be changed.
The only 2 values I changed from my config were
7D0-01-02
xxxx x8xx xxxx (the last two are a checksum in hex, I just added 8 to the current value as my previous value in the sixth position was 0)
7D0-04-01
xxxx xx0x xxxx (last two are a checksum again, mine changed from 9C to 1C)
2020FX4
El Jefe
Los Angeles
2020 FX4 Ranger
Your authorized dealer will install. Got mine at Sno Valley in El Monte. Cheapest I could find in my area. Ask for Stephanie.
Thanks for the info.... I am looking at them now on their website.
RedlandRanger
Moderator
Rob
Oregon
7D0-01-02
7D0-04-01
I had to write the entire APIM module in order for it to take. I have a 2 in the position where you have an 8 in 7D0-01-02. Do you have the 501a package on your Lariat? The Climate screen is functional on mine with that setting with Sync 3.4. If/when the official 3.4 comes out, I will most likely use that in order to fix any oddities that @UofMEngineer said might occur with the unofficial release.
Trey1940
Trey
I do have a 501a Lariat, which is why I was surprised your configuration didn't work. According to the F-150 sheet, these are the differences in the values.
Ford Ranger RCMUSTANG's Magnetic FX4 Screen Shot 2020-01-25 at 1.37.45 PM
I used 8 because it changed my original value of 0 from MMI Disabled to Enabled without changing anything else.
RedlandRanger
Moderator
Rob
Oregon
That is bizarre.... Thus far everything seems to work fine on mine - knock on wood....
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Based on 5,000 miles of testing I've picked up virtually nothing but condensation on the boost/breather side. Switched back to PVC only for the catch can.
Ford Ranger RCMUSTANG's Magnetic FX4 20200202_211022
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Should be no more non LED bulbs left. No hyper flash and non directional install.
Reactions: Doc
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Tailgate lock. Good luck stealing the tailgate. Prevents the tailgate from lifting off the hinge. Pretty thick gauge steel. McGard under contract to Ford. Just like the DeeZee tailgate dampener. You won't see them outside of Ford till the contract is over. VKB3Z-18168-A
Ford Ranger RCMUSTANG's Magnetic FX4 20200209_115408
Ford Ranger RCMUSTANG's Magnetic FX4 20200209_115136
Ford Ranger RCMUSTANG's Magnetic FX4 20200209_115127
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
For the extra rumble the B&O is missing.
Ford Ranger RCMUSTANG's Magnetic FX4 20200216_112327
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Project match front brakes.
Ford Ranger RCMUSTANG's Magnetic FX4 20200228_181845
Ford Ranger RCMUSTANG's Magnetic FX4 20200228_171812
Ford Ranger RCMUSTANG's Magnetic FX4 20200228_171206
Ford Ranger RCMUSTANG's Magnetic FX4 20191124_183416
Dmax
Denver, CO
2019 Ford Ranger Lariat 4x4
Just painting the rotors and what not? or new beefier breaks? Always following what you up too...
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Just replaced the rotors and painted the calipers to match.
