- First Name
- Jason
- Joined
- Feb 8, 2025
- Threads
- 45
- Messages
- 4,101
- Reaction score
- 3,988
- Location
- Corpus christi texas
- Vehicle(s)
- 2024 ford ranger, 2019 wrangler, 2018 mazda3
- Occupation
- Retired
Air moving over any surface is very little at the actual surface. There is a very small surface of air between the truck and the flow that actually moves hardly any. I cannot remember what it's called..... not laminar though. You will see it sometimes while driving because the water stops won't move from the hood when you are in the highway.
There is a lot of info on air flow if you read about wing design and aerodynamic shapes. There used to be a website that let you design things and it simulated running the thing in a wind tunnel so you could see the high and low pressure to improve your design for more lift or less drag
