Recommendation on 1st Oil Change & Service
KJA2
Kent
Indiana
I purchased a 2025 Ranger Lariat 2.3L in November. It now has just under 4K miles. In a couple weeks I plan to take a round trip of 2-2.5K miles, towing a 3.5K lbs camper. What is the recommendation of the group to get first oil change & service "before" or "after" the trip? Thank you
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
Before! You don’t wanna go much over 5k on ecoboosts. Sure some have but it’s cheap insurance. I do 5k changes and oil analysis on past Ford Ecoboosts or V8s show that’s a good place to change at. I’ve used Pennzoil Platinum, Quaker States Ultimate Synthetic , Mobil 1 synthetic and Supertech Synthetic (they now have a 15k and 20k miles synthetic and before that the 15k was the top and that’s what i used). All were solid and i could have gone past 5k but you lose what some of the oil does around 6k. It’s due to the Fuel oil dilution you get in the ecoboosts and how hot the 5.0 can run.
purdyd
california
I would do it before. I've seen enough oil analysis reports on here to suggest an early change, is a good idea.
And towing is hard on your oil so you might want to change early again when you return.
The oil life indicator may actually be useful so you might pay attention to that.
purdyd
california
its interesting because I changed my oil at 500, 5000, but my oil life indicator says I will not make 10,000 miles like I planned, it will be 9K
in fact I will end up changing at 7500 as I have a pretty significant road trip coming up and will exceed that 9K before I return
I had a 2K road trip in that first 5k but almost all short trips since then.
Maybe
Brock
CA
I don’t pay much attention to the meter. I usually for 1000 mile changes for a new vehicle and then 5k from there. Usually my meters say 45-50% at the 5k mileage mark. So i definitely change it as close to 5k.
purdyd
california
yes, normally that would be the case of me, ignore the meter, and change every 5K, on the 0s and 5's
But I am not going to make 5K according to the meter, even though I made it easily on my second change.
Maybe
Brock
CA
Not even making 5k? That’s crazy. What you been doing? Towing the whole time?
Buellsox
Scott
Tacoma, WA
Local 26 Union Plumber
1K% before!
Thats a no brainer
Wouldn’t hurt to do another one after the road trip or fairly soon thereafter. Cheap insurance and a great way to break the engine in. These Ecoboosts (any direct injection turbo engine actually) tends to dilute the oil down with fuel in short order between oil changes. Longer idle times and it only magnifies.
5K miles or 6 months whichever comes first is my threshold. Since I have a company truck my miles stay low so I just keep to a spring & fall o/c routine no matter the mileage. Keeps it simple and then I have Zero to worry about. Do it myself and I’m roughly $150/year in oil changes.
Cheap insurance in my estimation. My previous 3.5 Eco in a ‘19 F-150 seemed to like the intervals as it never gave me an ounce of engine issues.
purdyd
california
no just a lot of short trips
I’m second guessing whether I reset the oil change but I’m pretty sure I did.
but the miles remaining and percent look right,
NM Mike
New Mexico
I’d recommend an oil change before and after. You sre getting close enough to the 5k point to justify the first oil change. 2.5-3k miles of towing will justify a change afterwards IMO. You’ll be running higher RPM’s and temps while towing, so an early oil change afterwards is cheap insurance.
josephp732
Joe
NJ & FL
Before - 100%! I changed my 2025 Lariet's oil and filter at 500, 2,500 and then again at 5,000 miles. Now I' am on a 5k miles or 6 month OCI. Also, use a high quality full synthetic oil.
