RR 3.0 Wet Belt Driven Oil Pump - issues in future?
BLIZZARDIBLO
Portugal
X6
What do you guys think of this cheap wet belt and issues in the future? Until 2017 the 3.0 ecoboost oil pump was chain driven. .
This is a big engineering downgrade, and don’t come with things like less friction an emissions, because this is a fail on purpose design. .
Flak
25 Ranger Raptor
Sounds like a potential problem for future me, that idiot and/or amazingly gifted thinker
BLIZZARDIBLO
BLIZZARDIBLO
Portugal
X6
The issue is that this is no idiot nor stupid thinker. . This was reengineered to fail and to save money in chain, guide and tensioner, for it to cause issues in medium term. . Replacing the belt is serius job, removing front of engine cover etc. . It limits oil compatibility, and life time of the engine.
I think they should face a class action to start manufacturing chain and tensor to update this engines. .
richman555
Rich
Collegeville, PA
2025 Ford Ranger 2.7 XLT FX4
Software Engineer
According the Google Gemini AI - This is recommended for a 2.7 Ford Ranger - probably wise to save some money for around 80-100k for a wet belt replacement.
Recommendation TypeInterval (Miles / Years)Notes
Official Ford Schedule150,000 milesOften listed as the first major inspection point.
Preventative (Mechanic Advice)100,000 milesRecommended to avoid the "Ecoboom" scenario where belt debris clogs the oil pickup.
Severe Service / Short Trips60,000 - 80,000 milesIf you frequently tow, idle for long periods, or drive in extreme heat.
Why the "Wet Belt" is Controversial
The belt lives inside the engine and is constantly bathed in engine oil. Over time:
  • Chemical Degradation: If oil changes are skipped or the wrong oil is used, the rubber can soften or become brittle.
  • Debris Risk: As the belt wears, tiny rubber fibers can flake off and clog the oil pickup screen. This starves the engine of oil, leading to catastrophic failure even if the belt hasn't actually snapped.
  • Labor Intensive: Because the belt is inside the engine, replacing it requires removing the front timing cover and oil pan. It is a major service that typically costs $1,500–$2,500+ in labor.
Best Practices for Your 2025 Ranger
  1. Oil Changes are Critical: Change your oil every 5,000 to 7,500 miles. Do not wait for the "Oil Life Monitor" to hit 0% (which can be 10,000+ miles). Fresh oil prevents the chemical breakdown of the belt.
  2. Use Correct Specification: Only use oil that meets Ford WSS-M2C948-B (or the updated 2025 equivalent specified in your manual). The wrong additives can accelerate belt rot.
  3. Monitor Oil Pressure: If you ever see a flickering oil pressure light or get a "Low Oil Pressure" warning, stop driving immediately. This is the primary symptom of a degrading wet belt clogging the system.
daytoncarter
Dayton
This and weight were the two main reasons for getting the 2.3L MPC. After driving the dinky 4cyl 1000 miles, I can't say I'm wanting for more power.
To be fair, there are 300k and maybe even 500k mile examples of 2.7s in other Fords already. But that's over 3-5 years of hard use, let's see how the belt looks after 10, 15, or 20 years.
JimG
Jim
Scottsdale, AZ
2025 Ford Ranger Raptor
That is a bad thing. Good of you to point this out!!!
All the more reason for the following:
Change oil at least every 5,000 miles under normal use.
Only use full synthetic oil for better lubrication.
Only use oil that meets OEM specs.
If you’re a DIY guy check your oil and filter for rubber particles.
If you take your truck to a dealership for oil changes, make sure they check for particulate.
If you go to a quick lube at least ask for the filter back to take apart and look for rubber.
Timing belts and wet oil belts are not a good thing.
danmoochie
dan
florida
retired Sales manager
Keep in mind, this is not the same wet belt technology of the past. These new wet belts are made of Kevlar and with normal maintenance should last 250k miles. However, it is also recommended that you use full synthetic oil and change every 5k to reduce risk.
There are millions on the road in these engines with remarkably few failures. Nearly all negative points of view are simply FUD, passed on because the author of a post or comment did nothing more than read FUD coughed up by others. Also as has been noted here, the belts aren't simple rubber belts and are made with kevlar.
I personally plan to replace mine at 10 years or 100k miles, just as I've done with all of my other vehicles where I performed a "major" service and replaced all wear items like serpentine belts, timing belts, water pumps, thermostats, turbo and coolant hoses, etc.
There was FUD around timing belts in the past because a failing belt invites your valves to clash with the pistons, but here we are decades later with them widely used and accepted. Let's reign in the FUD and judge them on their track record.
Onceaneagle
Walter
2025 Ranger Lariat
US Army Retired
Maybe buying a Ford extended warranty offsets the cost of belt replacement, if you plan on keeping the truck long-term? Some dealers like Conklin Ford cover the engine and transmission for life, if you buy from them. Anyone heard of Ford's compensation program for wet belt failure under 1st Gen Ecoboost engines? Wonder if something similar applies to these engines, especially since Ford went from a timing chain to a wet belt? Anyone seen the statistics on how many Ford wet belts have actually failed verses total number built?
daytoncarter
Dayton
I think the 2.7L is a great engine, but I don't think I'd buy a timing belt engine any faster than I'd buy a oil belt engine. Keep in mind those wet belt pumps are only 7-8 yrs old at most, let's chat again at 10-15 yrs, rubber does naturally degrade it's expected.
I just don't want internal engine maintenance to be a design characteristic of the engine.
Sparkplugs, oil, filters, fine. Tearing the engine down as routine maintenance? No thank you!
We see this very differently; I don’t consider removing the front timing cover (even if it takes a few hours to do) as “tearing the engine down”.
Edit: I'll add that I think timing chains are just fine; I have nothing against them. But having spent a lot of time in shops, and having had cars with timing belts and cars with timing chains, I personally don't think any solution is much better than the next. I've seen timing chains wear from stretching causing engine idle or running issues. Chain guides are often plastic or polymer and wear, causing chain slap and even chains to jump the sprocket teeth. Tensioners can fail (with belts or chains). Replacing timing chains is not an easy task, but when you buy an engine with one you either commit to replacing it and it's components between 100k and 150k miles, or you roll the dice risking expensive failure. Same with belts, be they "external" or oil-bathed. Perhaps I'll sour on the experience of maintaining an oil-bathed belt in time, but having maintained high-mileage engines with chains and with belts, I don't see any one as better than the next with regard to reliability or maintenance or cost.
daytoncarter
Dayton
Well you're mentioning the most simple version of the job. Many cars timing belts and wet belts are engine out jobs. On the Ranger (Longitudinal layout), you might not necessarily have to pull the engine out (maybe so I haven't checked the book), but at minimum you do have to remove the front timing cover, which often involves pulling the radiator, intercooler plumbing, crank pulley, and dropping the oil pan to clean the pickup. It is a $1,500–$2,500 labor job. Treating that as "maintenance" is painful compared to a chain that just works.
Anyway, GM's LLT v6 had chain issues, they often failed within 150k mis. That's a design flaw. In most applications, properly designed chains have guides that last 500k+.
Again, the 2.7L wet belt is okay, but it's planned obsolescence.
I've seen too many people with Honda's and Toyota's cry into their checkbooks before their "reliable" cars hit 200k from failed, unmaintained chains for me to agree with that.
daytoncarter
Dayton
Fascinating, because statistically the chain is not the first thing to die w/o oil changes, it's the oil-fed variable valve timing, crank bearings, or cam bearings.
Anyway it's not like changing your oil is going to prevent the wet belt from deteriorating, maybe delay, but the belt is no longer a "lifetime" part.
This discussion makes me think of timing belts and how all the manufacturers went to them back in the day. Then most came back to chains because of how much timing belts (even though it was owner fault) gave the manufavturer a bad name.
They have to live with people telling others how their belt broke and destroyed the engine. The person wont mention that they failed to change the oil or belt on time, just that their engine got messed up from it failing. Then it starts this (incorrect) story that some company has this issue so stay away from them.
Thats the teality of what companies live with in designing engines.
