RR Oil Evacuation - Top Side Oil Change?
Hummeroid
Co Springs
24 SG RR
Test engineer
Hey all,
Has anyone done a top side oil change on a Raptor? Finding no info online as to if it works. Our 2.7TT Edge definitely does not allow this- the tube bottoms in some baffle or cavity of some kind, hoping that’s not the case on the Raptor.
Thanks!
Hummeroid
Co Springs
24 SG RR
Test engineer
Ok- tested the waters for everyone. The smaller tube I have fit down perfectly. The larger tube would not fit, so it just took a bit longer to evacuate everything.
I pumped everything I evacuated in to the new containers once they were empty and I apparently got basically all but a few tablespoons out. Very much in the acceptable range for me as I’ll be changing oil fairly frequently.
if you’re wondering why I’d do this: Basically zero mess. It’s windy whenever I have time to change my oil, so this is important to me. I’ve saturated my driveway from one big gust before. The evacuation system I have is also a nice way to get the spent oil to a recycling center without having to find containers to get it there, or deal with an oily pan/container combo.
I did find something strange while doing g the change though. The filter I removed was a different part number than what the owners manual calls out. See pic. I took out a 6714, and the manual calls out 2062.
Ford Ranger RR Oil Evacuation - Top Side Oil Change? IMG_1414
nikhsub1
Los Angeles
2018 Raptor
This is good news! I have a gen 2 raptor and you can NOT suck the oil out topside at all. I like how the filter is topside as well. I can change oil and filter with the mityvac in a tux and not spill a drop.
Hootbro
Delaware
2024 Ranger STX 4X4
The 6714 part number is the original equipment as built part and the FL-2062 is the Motorcraft service part. They do the same thing on the can filter motors where the original as installed factory filter is a different sourced filter and not a Motorcraft labeled part. It is a easy identifier to the dealership service department if you come in with issues and they can tell if you still are riding on the factory installed oil filter.
dew34
Michael
Grant Fl
2024 ranger raptor
retired diesel mechanic
Where are you drawing the oil from on the top side ? dipstick tube ?
killblue
Jez
Australia
2019 Ford Raptor 4x4
I've been using the dipstick tube for oil changes on my other vehicles.. Glad to hear it works! Might save me some time and mess.
