RR 3.0 Wet Belt Driven Oil Pump - issues in future?
daytoncarter
Dayton
@Lion77 - since we now agree that drivetrain loss and wheel weight only change the magnitude (the vertical offset on a graph) and not the actual shape of the power delivery, we can stop using wheel weights as a diversion. It lowers the final number, but it doesn't change the RPM where peak torque happens or rewrite how the engine breathes.
But let's look at the 30% advantage claim, since I think if it's true, it's probably only true on a dyno.
1. Using the Wrong Engine Specs: The dyno charts you posted are for the old 2.3L from 2019. The current Ranger uses the 2.3L MPC. This is a completely different architecture with port and direct dual injection and a new twin-scroll turbo designed specifically for better low-end response. I previously owned a 2021 Ranger and felt the same way you do—I need a v6. However, the new MPC paired with the revised software in the current truck fixed all of that. It spools nearly instantly compared to the older generation.
2. The Transmission Miss: You claimed these trucks are on the same 10R80 transmission. They aren't. Every current generation Ranger uses the 10R60. This is a lighter gearbox that shifted away from the heavy-duty F-150 variant. You're trying to prove a power deficit by referencing hardware the truck isn’t even using.
3. Displacement vs. The 200 lb Penalty: You are ignoring that the 2.7L hardware adds about 200 lbs of weight. The displacement difference between a 2.3L and a 2.7L is roughly 15%. Any performance gain you’re seeing is much closer to that ~15% displacement gap than the "33%" leap you claim. In fact, most of that gain is offset by the weight penalty of hauling that V6 and its cooling system around.
4. Real-World Performance Stats: If there was truly a 30% power gap in "work done," the performance delta would be huge. It isn't. Instrumented testing shows the 2.7L runs 0-60 in about 5.6–6.2 seconds, while the 2.3L does it in 6.2–6.7 seconds. In the quarter mile, it’s a 14.5 @ 94 mph for the V6 versus a 14.8 @ 93 mph for the four-cylinder.
If a truck has 30% more effective energy, it doesn't fight for a three-tenth-of-a-second lead in the quarter mile. You’re using outdated charts and technical "noise" about wheel weights to inflate an advantage that the actual stopwatch says doesn't exist. The 2.7L is a great motor, but for street performance, the 2.3L MPC is functionally synchronized with it because of its lower weight and more aggressive factory tune.
Now I'm glad you posted the dyno showing a tuned 2.7L, now that's where you could see a major advantage since I think there's way more head room in the twin turbos and 2.7L than the 2.3L.
BriSco
'24 Ranger XLT, 2.7L V6
They are not going to write on your Tombstone you had a Big Dick for having a 2.7L.
Looks like you already did.
Thanks!
Hootbro
Delaware
2024 Ranger STX 4X4
Thanks!
Do not be flinging your dick around any Cars and Coffee events around the 3.0L Raptor guys, might be a little embarrassing for you.
BriSco
Thanks for the advice. It’s always helpful coming from those who have tried it, I wouldn’t have done it anyway, I have no envy for a Raptor.
Regardless your’re a hoot bro. You really do need to end your obsession with both the size of my member and the size of my engine. It’s not healthy. Just go upstairs and ask your mom.
I’m sure she’ll tell you “That’s not healthy Hoot!"
I bet the 2.7 ranger is a blast to drive. My 2.3 is a quick so i bet the 2.7 really feels like its moving.
danmoochie
dan
florida
retired Sales manager
I does move great. Like I have stated, and having had the RR with the 3.0, my XLT FX4 with the 2.7 feels every bit as fast, if not faster to me.
Dang. I hope they dont have a 2.7 ranger at the dealer so i cant test drive one. Since i dont off road or tow, acceleration and speed feel means alot to me so it would be hard to not want one ifni drove it and it felt so much faster. Thats why i have the procal on my 2.3, it feels so much quicker 0-60
It's not that much faster. After driving 4 bangers in the 70s and 80s, I swore to never buy a vehicle with a 4 cylinder. The 2.3 Ranger changed my mind. I had a '21 with the 2.3 and was very impressed with its power.
What you do get with the 2.7V6 is higher torque, and IMO a smoother and quieter engine.
My 3.0L is bigger than all ya'lls 2.3L and 2.7L's....:crackup:. But seriously, all the engine options have their pros and cons.
The 2.3L EB is miles ahead of the old Duratec 2.3L NA and even the 3.7L V6 NA from the laye 90s to early 2k in older gen Rangers before the reboot of the series in 2019.
The 2.7L is a nice step up from that for those that do a lot of towing and the 3.0L is the rowdy hooligan jumping off the cliff while holding torches and yelling "send it!!!"
Don't forget, you can tune all 3 engine options. My 3.0L with Pro Cal is 455 hp / 536 lb-ft. Its a riot and I love it. Aside from the amazing exhaust note from my 2016 Mustang GT with Stage 2 Power Pack that also made 455 HP, I prefer the broader torque band of the Pro Cal tuned 3.0L over the Stage 2 Power Pack 5.0L which didnt hit peak torque til 4200 rpm and really was anemic below 3k.
Ford Ranger RR 3.0 Wet Belt Driven Oil Pump - issues in future? 20190629_121800
Ford Ranger RR 3.0 Wet Belt Driven Oil Pump - issues in future? IMG_0074
danmoochie
dan
florida
Not to disagree, but significant to the stock 2.3 vs 2.7 and very little between the 2.7 and 3.0 RR due mainly to weight. Just do a google search, many test times posted.
I agree, but I'm not that kind of driver.
I do love my 2.3 with the procal. It is definitely alot of fun.
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
With out reading all the post's.
From my understanding Ford went to the Wet Belt partially because of Harmonic issues with a chain.
I looked at extended warranties today. Catastrophic motor failure would be covered as long as it was before the scheduled replacement time of the wet belt. That's with replacing with genuine Ford parts. Same with timing belt. i would put a $20K coverage for motor or transmission failure.
2.3L XLT instrumented testing on Car and Driver (still respectable for a 4-banger):
C/D TEST RESULTS
60 mph: 6.2 sec
1/4-Mile: 14.8 sec @ 93 mph
100 mph: 17.7 sec
Results above omit 1-ft rollout of 0.3 sec.
Rolling Start, 5–60 mph: 7.8 sec
Top Gear, 30–50 mph: 3.7 sec
Top Gear, 50–70 mph: 4.5 sec
2.7L XLT instrumented testing on Car and Driver:
C/D TEST RESULTS
60 mph: 5.6 sec
1/4-Mile: 14.5 sec @ 94 mph
100 mph: 17.2 sec
Rolling Start, 5–60 mph: 6.4 sec
Top Gear, 30–50 mph: 3.1 sec
Top Gear, 50–70 mph: 3.8 sec
3.0L Raptor instrumented testing on Car and Driver:
C/D TEST RESULTS
60 mph: 5.3 sec
1/4-Mile: 14.1 sec @ 97 mph
100 mph: 15.0 sec
Rolling Start, 5–60 mph: 6.1 sec
Top Gear, 30–50 mph: 3.0 sec
Top Gear, 50–70 mph: 3.9 sec
4 tenths between the 2.7L and 3.0L is a royal beating in the 1/4 mile. There's no replacement for displacement, but the 2.7L puts up a good fight! Forget the 2.3L...Also note the Raptor is pushing a lot more weight on the chassis, tires and wheels than an XLT, yah know that parasitic loss thing. Anyone wanting to make a Road Raptor and throw on street tires and lightweight wheels will gain another 1-2 tenths with no other mods where the XLT is running a street tire configuration already that's considerably lighter.
Both are great engines in their own right, but the 3.0L also has much beefier pistons and oil cooling galleys that the 2.7L doesn't given it's HP oriented nature. It has bigger turbos and a high flow induction system to maintain power throughout the rev range, obviously more bore and stroke in a square setup, so that's where the extra power is coming from, it's literally a "hot rodded 2.7L".
3.0L pistons on the Left, 2.7L pistons on the Right. Notice that BOTH have cast in steel ring liners. You can thank the Power Stroke 6.7L Diesel engine development team for that nugget, same with the CGI block as both are diesel tech.
Ford Ranger RR 3.0 Wet Belt Driven Oil Pump - issues in future? Screenshot 2025-11-07 191006
Ford Ranger RR 3.0 Wet Belt Driven Oil Pump - issues in future? Screenshot 2025-11-07 190950
The skirts and wrist pin bearing areas are BEASTLY on the 3.0L pistons. Notice the 3.0L piston oil cooling galley holes? Also, diesel tech from the 6.7L. Hellooooo Power Stroke!
0-100 MPH is OVER 2.2 seconds difference though 2.7L vs. 3.0L and a whopping 2.7 seconds for 2.3L to 3.0L, that is HUGE in roll racing, that's where HP really comes into play, on the back half or at higher speeds or when moving more mass. From Car and Driver:
Ford Ranger RR 3.0 Wet Belt Driven Oil Pump - issues in future? 1768742104942-nh
"We think the V-6 is a meaningful upgrade, and for folks actually using the Ranger's 7500-pound towing capacity or its 1711 pounds of max payload (4WD only), the added juice during passing maneuvers is a sweet treat."
Naw that couldn't be the case, cause only the 2.3L makes sense....right?
Also note that gap grows even bigger between the V6's and the 2.3L if all 3 are Pro Cal tuned. The V6's have a lot more headroom. But since all the V6's have the wet belt of doom...we should just buy the 2.3L and call it a day.
