Shortest hubcentric spacers?
Fordfknranger
Travis
South Dakota
2025 Ford Ranger Raptor
Just wondering what the shortest hubcentric spacers you could run with regular stock RR wheels. I'm hoping to run 1"... Do the oem wheels have pockets like the Bronco wheels have?
(I'm running 35x11.50r17 Toyo At'3 tires with 2" Level)
Thanks
gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
Wheel adapters USA has some 3/8 and 1/2” slip on hubcentric ones with different lugs to bite more thread that you’ll loose.
Ford Ranger Shortest hubcentric spacers? IMG_0130
Fordfknranger
Fordfknranger
Travis
South Dakota
I have tried those they do not work. The lugs don't fit through the wheels. They would not take them back either. Aholes to deal with.
AdventureLab
Brit
St George, UT
'24 RR
How close were they to fitting through the holes in the wheels? I would love to keep the stock wheels on ours, but the 4mm spacer I cut is obviously not hub centric, so I'm getting some vibration issues at speed. I don't mind drilling the wheels if the lug nuts are close.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
I'm running the 1.25" spidertrax on the factory wheels with 35's. Which gives me like a +25mm offset. No issues.
AdventureLab
Brit
St George, UT
'24 RR
We have 35" Nitto Terra Grappler G3's on this one. That offset wouldn't work with our tire. A 10mm spacer would probably be perfect.
Ford Ranger Shortest hubcentric spacers? G18A6035
ColeTrainsRR
Cole
Minnesota
E-Tec 3
I have 1" BORA brand. They were expensive but just right
