josh2201
ON CA
2025 Ranger XLT
Tight fit! I think I got about as much bass as you can without modifying the interior or having a box sitting on your back seat.
Tight to the seat but the deep grille provides the space for the impressive excursion on this thing. After mounting the sub to the box, I was really skeptical about it fitting, but, it does with 0 playroom. Hertz mps250. Would recommend! Songs with tight bass make this thing hit like a roundhouse kick from Chuck Norris 🤔
Powered by fosgate prime r2-500x1 👌
Box detail: outer dimensions 25"long. 5" bottom/3" top. 14" high. 1/2 mdf with a brace inside. Don't think the magnet will clear inside with 3/4 so I played it safe. Subwoofer has to be offset as theres some metal in the seat that would interfere. Also mounted as low as possible so the magnet clears the back.
I hit my target volume with this box of .5cu ft. More space than the cubby under the seat.
Ordered some front pioneer component 6x9 + tweeters for install in the coming days.
Hope this helps anyone wanting a rear seat sub setup!
Ford Ranger Sub install behind rear seat! 20251007_090507
Ford Ranger Sub install behind rear seat! 20251007_084601
Ford Ranger Sub install behind rear seat! 20251007_091141
Ford Ranger Sub install behind rear seat! 20251007_104053
Ford Ranger Sub install behind rear seat! 20251007_104734
ZombieDropper
Jürgen
Phoenix, AZ
Facilities Manager
Nice job but seems like a lot of work. Another option would have been the JL Audio Stealth Sub Box. Paired with a Kicker 400.1 it hits really hard. And you won't lose your jack storage.
Ford Ranger Sub install behind rear seat! 20251008_063907
Ford Ranger Sub install behind rear seat! 20251008_064053
josh2201
josh2201
ON CA
2025 Ranger XLT
Well that's a great option, I couldn't justify spending 1600+tax cad
I spent 645 for sub and material. And a few hours of my time.
This sub also handles a fair bit more power than the jl tw1.
Zach@Granger
Gold Sponsor
Zach
Granger, IA
1979 Bronco
Car Dealer
Box detail: outter dimensions 25"long. 5" bottom/3" top. 14" high. 1/2 mdf with a brace inside. Don't think the magnet will clear inside with 3/4 so I played it safe. Sub has to be offset as theres some metal in the seat that would interfere. Also mounted as low as possible so the magnet clears the back.
I bet you have great beats now! Very nice!
bigb
Tucson
2025 Ranger 2.7
So for us folks with minimal audio knowledge where do you get the signal? Assuming at speaker level? Second, is there any control available when driving or is everything pre-set on the mono amp?
SnyperX
Mark
2024 Ford Ranger XLT
For my setup I have a AudioControl LC2i line converter that gets the signal to my Kicker HS10. I have the LC2i connected via a harness I bought from PlugandPlayKits.com. I have the NON-B&O stereo. Harness requires disassembly of the interior in order to get behind the 12" screen to install the harness. I didn't want to splice into the factory harness so it had to be done.
LC2i Harness for 2024+ Ford Ranger
jrRaptor
Maize, KS
Nice! Been thinking of something like this. Box dims are greatly appreciated!
I hear the OEM jack is worthless for the Raptor anyways.
ZombieDropper
Jürgen
Phoenix, AZ
Facilities Manager
Sounds Good Stereo sells a pre-programmed Kicker Line Out Converter that is truly plug and play for the Ranger with a B&O system. It plugs right into the factory amp harness behind the seat. All the set up and programming is already done for you. No cutting of wires. It provides a flat bass signal for your mono amp. Otherwise your stuck with the Ford factory bass roll-off which will make your sub sound terrible. It's worth every penny.
https://soundsgoodstereo.com/produc...read-description-below?variant=43758553301204
Ford Ranger Sub install behind rear seat! 20250927_113616
josh2201
josh2201
ON CA
2025 Ranger XLT
Located under front door sill, I tapped into rear speaker wire.
And my amp has a wired remote bass control, which I mounted up front so I can adjust bass on the fly.
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
You've posted that link before but everytime i click it you can't choose removing the bass roll off option.
ZombieDropper
Jürgen
Phoenix, AZ
Facilities Manager
It's hit and miss. It takes time for those guys to build the wire harness and program the LOC. I think they block out that option when they run out of stock.
White willy
Earth
2025 Ranger
This is what’s keeping me from doing mine for now.How much actually has to torn apart?
I really wish there was a write up,or good video explaining it all.
Hats off,gotta be a nice improvement for sure!
SnyperX
Mark
I used this video. Its for an Australia Ranger, but still provided good info. A LOT has to come out unfortunately I was adding sound deadener as well so it all worked out.
josh2201
josh2201
ON CA
2025 Ranger XLT
This isnt all necessary. I tapped into door speaker and thats it. No loc. No unnecessary interior tear down. My results are good. No bass roll off. My bass goes up with the headunit volume all the way up til my ears say thats enough. Usually around 20. And to set gain. Youre hitting a desired voltage on the amp output with the
At 75% volume on headunit. So ya, your amp will put out the power you want thru the range.
White willy
Earth
2025 Ranger
Which wires and where did you tap for that?
Inquiring minds would love to know.
