The ULTIMATE guide to lifting your Ranger Raptor
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Awesome guide. A few on here have been spewing some bad information on lifts.
Question. I see that in your Forscan tutorial, the ending positions still read 2mm. I believe mine was the same.
Is there any way to force it to 0mm? Also, there is mention of a temperature calibration in Forscan but no one has figured that out.
Thanks!
Thanks, appreciate that. Its a pretty controversial issue so figured it was time to lay it all out. There will always be people who disagree but cant win em all.
yeah its random, some cars get to 0, some dont. We just chalk it up to variance in mass produced vehicles. Not sure if it would be possible to prove that it has a positive or negative affect on live valve.
ag02m5
Google
It would be nice if they have a few "off the rack" options prepared for common fitments, as I've had to have springs custom made, in the past. That's not difficult to have done, but it's an extra step.
Ok. See what you are saying.
Bushmechanic
South East United States
We are based in Australia. Our spring options are completely different to what is available in the USA. Unfortunately for you guys, in this rare instance, the options are less than in Aus, which is very different to most circumstances regarding accessories and mods.
But regardless, we believe that offering generic "X Y Z combo, use this spring" advice is more unhelpful than helpful. There is so many different combinations of accessories that all have different weights. The proper way is to get your truck sitting with all of the constant weight, then measure sag and determine the appropriate spring rate to return to stock. That way, your getting as close to perfect for YOUR setup as possible.
I'm glad to hear that's what you suggest.
CapsRap
Brandon
Arizona
2025 Ford Ranger Raptor
Firefighter
CapsRap
Brandon
Arizona
Firefighter
@GregFoutz
What is your response to this information in relation to your perch collars?
Specifically, with 35” tires and your collars, where does the tire end up at full compression?
markferry
Mark
El Dorado Hills, CA
2013 Raptor
realtor
I will post some this week when I get a chance. 2” front, 1” rear spacers. I also installed his UCA and HD clevis steering upgrade. It rides amazing,
Do you have any side pics on level ground? Also, just confirming you did front and back spacers, correct?
CapsRap
Brandon
Arizona
Firefighter
awesome, thanks!
GregFoutz
Greg
Mesa, AZ
F150 Raptor, Bronco Raptor
off-road geek
@GregFoutz
our collars dont change anything with full cycle of the suspension. So the truck will still bottom out at the same spot. The only thing the collars do is add preload to the spring so it will sit taller but nothing is changed in full cycle and positions of cycle.
GLW
Missouri
Do you support that it is a must to recalibrate live shocks regardless of method used to level/lift?
GregFoutz
Greg
Mesa, AZ
off-road geek
We have customers that do and some that dont recalibrate. I dont think its mandatory but I would suggest to do it if you can.
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
@nedmo Do your spacer thickness to lift ratios hold true for both the front and rear or the Ranger Raptor?
"We made our own perch collars, made our own strut spacers in varying thicknesses from 1in lift all the way up to 3in lift. 3in lift was too much for the CVs and ball joints, so we only sell up to a 2in/32mm thick spacer.
1in lift = 16mm thick
1.5in lift = 24mm thick
2in lift = 32mm thick
3in lift = 40mm thick"
So does your 32mm spacer also raise the rear by 2"?
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
All spacers we sell are interchangeable front to rear and provide the same amount of lift on either end.
YukonRanger
Yukon
@nedmo If you wanted to go up to a 3" Lift is there anything that can be done to mitigate damage to tierods\CV\Ball joints?
My new raptor is arriving soon and I'd like to start preordering parts
If 2" is the safest so be it, I'll work within that limit for now and wait and see what aftermarket delivers in the future. Portals seem awesome but the price is steep and I'm worried about investing in them up here in the Yukon because we salt our roads....scared they will corrode over time.
Seems like the FOX live valve is both a blessing and a curse on these trucks. You are either stuck forking over 20K for portals or somewhat compromising the design for just a tiny bit more clearance. The stock sidestep rails are somewhat self defeating too, silly design. Sure woulda been nice had ford made the truck with 35's standard and wheel wells that would fit 37-40.
