Water leaks from bed rail caps.
Rangerjimm
2025 Ranger Lariat 2.3
alrashid2
PA
I didnt like the way the silicone looked so I bought some 1" closed cell foam and cut it slightly larger and thicker than the stake pocket holes. Then put the caps back on. Seems to be working well. I also put black vinyl patches over the holes inside the bed.
Hey brother, could you share where you got the foam? Not sure of what type/size/thickness to get but this is a great idea!
I'm also thinking of just getting some flex tape and sealing the holes on the bed rail from the underside. I'd never see it and it might not be as good as the writeups here but I don't need waterproof, just better than the buckets of water I am getting currently!
Rangerjimm
https://www.amazon.com/dp/B07YGNHB31?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_1&th=1
You will have to trim to the correct thickness and size.
alrashid2
PA
Rangerjimm
Thanks for sharing! So you didnt compress the 1" thick foam down into the pocket hole? Looks like they sell a 1/2" too so maybe that'd be worth trying
Nope. The depth ranges from 5/8-3/4" Different as you go from front to back. If the piece is too thick it bulges the center of the cap up. You can cut it with a really sharp knife. I used a fish fillet knife.
