wires for trailer brake controller '24 Ranger?
jedadiah
Jed
Kentucky
The Tekonsha and Redarc both work really well. The pro of the Tekonsha is the lever that you can use to actuate the trailer brakes. The con is that it’s big it can be awkward to find a good mounting spot. The Redarc has a remote knob, so you can hide the unit and find a spot that you like. You have to push in the button to actuate the brake, which is more awkward. Both work well with their accelerometer based braking. I’ve used both, and chose a Redarc on my 5G because I couldn’t find anywhere I wanted to mount my Tekonsha. It’s great that the 6G has a real TBC connector. It was obviously designed with one in mind, so why isnt in the manual, so owners wouldn’t need to sleuth it out themselves?
jedadiah
Jed
Kentucky
Hi Stranger, you do great work for those of us who don't know electronics. At the risk of making it obvious that I am dumb as a post about wiring, a Tekonsha Prodigy P3 with a PBT-GF15 connector that mates to the plug that I found on the '24 Ranger XL is sold by E-trailers as item # TK99UR. Same with an E-trailers Tekonsha Prodigy P2, item #TK96HR; & an E-trailers Tekonsha Primus IQ item # TK67HR. Does that mean that those are also plug 'n play for a Ranger, too, or is there something special about RedArcs?
I meant to quote you in post 94
RangerDangerStranger
Chris
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
If it will work with the current Bronco then it will work with our current Rangers it looks like. Comes down to the pinout in the connector. If it matches the connector, which is the same as the Bronco, it should work.
Chris
SF Bay Area
Cool Dude
Good work!
My REDARC liberty is suppose to deliver today but unfortunately the REDARC 331-TPH-007 Bronco harness will not get here until Monday. Plan is to slave it in and hang test it while I wait on center console switch panel to come in from Australia from Pirate Camp Co and then do a finish install.
Keep us updated. how do you plan to test it? Do you have a trailer?
craigc
Craig
Allen, TX
Good work!
So are you ordering the squeeze connector for the other side of the harness that plugs in to the right of the steering column? If so, this actually looks like the right combination to work. My parts guy at my dealer said he could get that controller but didn't know about the harness. The gray connector looks right for the TRM side, but not sure about the control side.
FYI, the squeeze connector part # is ML3Z14529AC
Helena-disappointed
Norm
Montana
24 Ranger XL
The Tekonsha TK99UR TBC, which is a Prodigy P3 with the PBT-GF-15 connector that mates with the '24 Ranger XL's included wired plug, is listed by e-Trailer as compatible w a '24 Bronco.
Helena-disappointed
Norm
Montana
24 Ranger XL
The E-trailer RedArc Liberty, item # RED67CR, appears to come with the PBT-GF15 connector that plugs into the plug on the '24 Ranger.
craigc
Craig
Allen, TX
Ah I see. it has the dial switch. Wondering where that can be installed nicely. Guess there's no way without drilling a hole in the dash panel somewhere or getting some center console panel like Hootbro mentioned. There's no blank panel to put it in on mine like they show in the photos. Would be nice if there'd be some way to use the factory switch or at least that pop out panel by the steering wheel. Surely at some point Ford will put one out....maybe...
Hootbro
Delaware
2024 Ranger STX 4X4
Below is the switch panel I have on order with Pirate Camp CO:
https://piratecampco.com.au/collections/electrical/products/sc-001
This should fit our North American XL and XLT. They offer another model for the Raptor and should fit North American Lariat and Raptors with the 12" screen.
They use the Toyota Short Switch format cutouts. I have on order from REDARC their switch insert for the same cutout:
https://www.redarcelectronics.com/us/switch-insert-to-suit-toyota-mitsubishi
I will admit I am buying this switch panel at risk assuming it will fit.
Chris
SF Bay Area
Cool Dude
Let me just take a minute, First i want to thank especially HootBro and Helen-disappointed. Between us 3, we solved the '24 Ranger TBC issue. As far as i know, we are the first to understand it's inner workings, and have claimed a solution. Thank you and Congratulations!
Chris.
Helena-disappointed
Norm
Montana
24 Ranger XL
Thanks for the credit. I just found a plug where others had shown they had found it on ExplorersST videos. Stranger's electronics expertise was the key. I am very impressed by him & Hootbro & others on this forum.
Helena-disappointed
Norm
Montana
24 Ranger XL
Good luck, sorry that the TBC soured you on your new Ranger. Seems like the solution is right around the corner! Good luck, what do you think you're gonna buy to replace it?
Hi Stranger,
I just saw your 7-29-24 post. It wasn't just the TBC issue; it was the lack of adequate bed rail reinforcement, so that J- braces, which are backordered, were required to carry > 88 lbs, so no topper. The dealer didn't want to wait much longer to buy back my truck, & his service manager couldn't get an answer from Ford or Tekonsha on TBC compatibility. As I posted, there were also cracks developing in the bed floor after only one 3-mile trip with a light load in the bed. It just seemed that Ford made a poodle, not a Ranger.
I've been looking for a truck. I've found a new RAM Tradesman quadcab V-6 3.6 L e-torque 4wd 6'4" bed for about $13k below MSRP, but it's ~4" taller, 2" wider, & about 16" longer than a Ranger, & it won't fit in my garage. So maybe I'll buy a used Tacoma.
Chris
SF Bay Area
Cool Dude
Have you looked at the frontiers? I had a '19 Tacoma. Eninge was wheezy, only a 6 spd trans trans and a complsite bed. Also, only a C type frame, Not fully boxed. Frontier was a Good truck, I had a '22 though a bit on the heavy side, Cast iron spindles, and that's a big piece! But Eninge was great, fully boxed frame, and 8 spd trans. Current Taco is a disgrace IMHO. Let us know what you get! ?
Helena-disappointed
Norm
Montana
24 Ranger XL
Thank you!
