RC MUSTANG Azure Gray Raptor Build
Midlifec
Livonia, Michigan
2025 Ranger Raptor.
Unfortunately, Maxbore, who I used to get stock ones ported from, has passed away. 65mm Bore plus low profile shaft. Luckily for me this was the same exact one from my 2019 that I saved.
Sorry to hear that. Thanks for the update.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Final piece of a complete Air Intake system. Got rid of the tornados on both sides.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260321_102047
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260321_102952
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260321_102945
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260321_103201
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260321_103147
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260319_191451
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260306_081508
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Truck has a cold idle stumble. These helped with the 2019. So, I'm giving them a try. MSD coils.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260328_175911
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260328_193509
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260328_200036
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260328_200045
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
19.14 mpg with throttle body and now up to 19.4 mpg since the driver side inlet pipe. Didn't hurt anything. Cold idle stumble has been smoothed out with the coils.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Started with adding a lower bracket to the radar to solve recurring blocked radar and solving the lower shutter removal error code. Cut the end of the shutter flap and silicone into the frame. Shutter removal issue turned into intercooler install. Installing intercooler turned into charge pipes. Intercooler could have been maybe a half hour swap. Charge pipes were not a fun one to install. Left the from shutter frame on to help funnel air directly through the core. No radar obstructing the intercooler should really show lower and consistent temps.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_140152
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_124156
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_124816
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_124822
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_172901
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_172849
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_175256
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260404_175333
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Since none of the stock brackets are used to secure the charge pipes i found these reverse osmosis brackets to help secure them.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260408_142347
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Lot of work cleaning all the brake dust off and getting them ready to powder coat. Code orange to match.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260405_163325
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260405_163307
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260405_163250
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260408_174037
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260408_193403
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Was able to reuse rear crash bar plugs. Should keep the moisture out.
Do you by chance have the part numbers? I tried to read at least that rear plug but nothing came up so I might be reading it wrong. I can't find suitable plugs for the front and if I could just get OE Ford ones from the 5G I'd do that.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
They came from my 2019. I think they're no longer available. So, you'll have to look for wrecked 5G ones. Might even be able to get them for free if you get lucky. The front are plastic covers and the rear are rubber plugs.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Since the stock bed lights weren't that bright and the gas cans covered them as well, I piggybacked a few more LEDs to them. I may tie in a couple more at the bulkhead later.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260412_185813
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260412_185950
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Forgot to post this from Feb 4th. Lol. 3D printed dash mount. Using it for my GMRS radio handset.
Ford Ranger RC MUSTANG Azure Gray Raptor Build FB_IMG_1776221510641
Ford Ranger RC MUSTANG Azure Gray Raptor Build FB_IMG_1776221517012
Ford Ranger RC MUSTANG Azure Gray Raptor Build FB_IMG_1776221524526
Ford Ranger RC MUSTANG Azure Gray Raptor Build FB_IMG_1776221528624
Locust13CT
Tom
CT
Aircraft Inspector
Could you confirm those MSD coils are the Part# 826016 kit?
Backordered from msd until 7/30... Im throwing in some fresh colder plugs, might as well upgrade coils while im in there. Good find! Applications list ecoboost 3.0 v6 but doesnt specifically list "Ranger Raptor". made it hard to find...
**Update** found stock on SummitRacing, also kit# 826036 is the same kit just with all black coils.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Followup, between the coils, driverside intake pipe, intercooler and charge pipes. I'm now sitting at 20 mpg on this tank. I will say most of that are the coils. That's another .6 mpg increase.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Matched the rear row hooks. Code orange. Since I couldn't powder coat them, paint will have to do.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260415_180209
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Had to fab up a couple spacers real quick for the bed extender.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_161225
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_162243
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_162330
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_153721
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_162520
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260417_162625
