2024 XLT 2.3L power loss going around corner
CoryB
Cory
Virginia
This has happened to me twice now, once turning in each direction.
I rounded a 90 degree right-hand corner without having to stop (the light was green for me) and the truck lost all power for (a very long) 1-2 seconds. The accelerator pedal didn’t respond. The truck just coasted. Then, just as suddenly, the pedal responded and off we went.
Yesterday I turned a left corner from one road onto another (no stop sign) and the truck didn't respond to me pressing the accelerator pedal. No “Check Engine” light, no errors, nothing. Then it took off after a couple of seconds like nothing was wrong. The same thing happened tonight but while turning right so it’s not direction dependent.
Of course I cannot make it happen at will, it’s just totally random.
The truck has under 1000 miles (7xx) on it. Gas level was ~2/3 of a tank of Exxon 87 octane. Outside temp was in the 60s and the truck was fully warmed up In both cases.
Any ideas? I’ll be calling the dealer tomorrow.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Sounds like traction control is limiting power?? Did you get flashing yellow traction light while you had no power?
Try turning it off or don’t press down so far on throttle while mid corner?
CoryB
Cory
Virginia
Interesting thought. I didn’t notice any lights but I’ll try driving with the traction control off and see what happens. Thanks!
stuartmunto
Stuart
Yeah sounds like traction control. Speed, wheel slip, steering input, vehicle lean and throttle input all factor into traction control. My guess is you upset it by either being too quick, too much steering input or it detected too much lean or wheel slip
embedded rock
Earth
One truck, two motorcycles
Seems like some control unit calculations being performed to determine which gear to select. Once the gear choice was determined, the trans downshifted and away you went.
BriSco
'24 Ranger XLT, 2.7L V6
I've had this happen several times as well. 2.7L V6 here. After rounding the corner the accellerator is dead for 1-2 seconds. Very disconcerting. I can't duplicate either. Dealer service dept shrugged their shoulders.
It was not in wheel slip, no traction control light no downshifting that I could detect. Just dead accellerator pedal.
tubingchamp
BC
2024 2.7 Ranger Lariat
Could it be some sort of ESC / rollover protection?
CoryB
Cory
Virginia
I doubt it. I wasn’t going fast but things just stopped happening. Last night I was watching a YouTube video and the person said the shifting in Normal mode feels strange to him, but it’s fine in Sport mode. He said it hunts or hesitates sometimes in Normal - which is what this could be. I may try driving around in Sport for a while and see if it happens again.
tubingchamp
BC
If you find a way to reproduce it, also give it a shot in manual mode.
I'll hit some corners a bit harder today and see if I can get the same thing to happen.
Designguy96
Bryan
syracuse, ny
2025 Ford Ranger
This has started to have this happen for me as well. 2025 with the 2.7. Truck has ~5000 now and I didn't have any issues until the past couple weeks. I've had this happen twice, seems to be random. I glide through a turn and when I go to accelerate nothing happens for like 2-3 seconds and then the transmission catches. I am planning to take it to the dealer, but I'm sure they won't do anything except maybe reset it. Looks like this issue has been posted on the highway safety website at least once. I'd encourage anyone with the issue to put in a report. Unless the dealer finds a solution I will be doing the same myself.
Vehicle Detail Search - 2024 FORD RANGER (SUPER CREW) PU/CC RWD | NHTSA
While I haven't experienced it in my '24, I did in my '21, and always left turns as you described it.
Blowndodge
Brad
Southern Utah
I've noticed that when I slow down and the truck is still in a high gear with the RPMS at about 1300 I have no power until I press the peddle further. I just wrote it off to being in a high gear that's not creating any boost. The truck figures it out and down shifts and the power is back. But for a few seconds not much happens. I drove it in manual mode and didn't let the RPMs drop below 2,000 and it never happens so I'm just believing the truck stayed in a higher gear and didn't have any grunt.
joecounty2025
joe
texas
2024 ford ranger xl stx 4x4
Mine did it today, filled up with gas, reset the trip, put it in drive , pushed the + button on shifter when I started moving, then the minus button till I was on 6th gear, intersection light was on yellow so I kinda hurried through it, turned left, pressed on accelerater, nothing for 2 or 3 seconds, came home, then about 1 hour later, drove it again, left it in drive didn’t mess with deleting gears, made several turns, right and left, nothing
Hooked up scan tool no codes, did not illuminate engine light or anything like that
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
this happened to me twice for the first time yesterday. Over speed bumps, throttle and no response for a second or two. Scared me.
