2025 Ranger - Bed 12 Volt Outlet - Final Update
SLJ
The Finger Lakes
I'm just going to use the blank panel that's there on my '25 XL. Adding USB, a 12V SAE port, and a light so I can see when the cover is closed.
Will get the 12V from the trailer tow harness.
bigb
Tucson
2025 Ranger 2.7
So I'm assuming tapping the tow harness for 12 volts doesn't make the trailer tow module think there is a trailer attached?
pezdyspensr
New England
2024 Ranger STX
Was thinking of doing this on my XL as well, but I was hoping not to trigger the computer upstream for any reason. And is your trailer harness OEM or aftermarket? Keep us posted.
SLJ
The Finger Lakes
THe #4 pin of the 7 pin supplies a constant 12 volts for charging the camper batteries, not lights or brakes so it's doubtful it will trigger the module. I can check easy enough beforehand.
For the people running non-oem stuff, how are you keeping the plugs and usb from corroding?
pezdyspensr
New England
2024 Ranger STX
in your case, are you running a black down to the rear bumper and splicing inline to the tow harness there? And is this an OEM tow package or aftermarket? I know the Curt 7 pin kit asks you to run a black straight to the battery.
SLJ
The Finger Lakes
I'll run both + and - to the tow harness. It's a factory tow harness so there's already a ground wire there for the 7 pin.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Adhesive shrink tube, custom TPU cover, and dielectric grease
pezdyspensr
New England
2024 Ranger STX
Don't worry, the Scanstrut is a superior 12 volt socket. Mine works perfectly and the door locks open or can be used as a plug retainer. Best 12 volt socket I've used, you can tell right away by the feel.
How do you ensure waterproof connection at the back of the panel with the Scanstrut? They seem like they expect a dry environment at the back?
Loudpa
Wonder if it's plug and play for the 2026 model year?
XLT
bigb
Tucson
2025 Ranger 2.7
I don't really think it will be an issue, it's up pretty high and the wheel liner keeps the splash away from that area. Plus I live in a dry climate with little rain and no snow. I've had the truck since October and it's only been driven in the rain once. If anything does happen to it I'll just replace it.
i ordered one. 75 bucks and 9 bucks shipping from autonation. should be here before saturday
