2025 Rangers 10R60 Transmission ~ Klunk & Jump
Not-So-Good!
So. Jersey
2025 Ranger Lariat
In January 2026, I bought a new 2025 Ranger XLT. After 700 miles the transmission would make loud metal noises and jump when starting from a stand still. Truck would not be in gear. I took it to the dealer, and they confirmed a problem so they checked the PCM and reprogramed it and reinstalled solenoid body strategy (just writing what the dealer wrote). At 1,400 miles it happened 3 more times in a week. Dealer verified the issues again and removed and replaced the value body, etc. Then at 2,100 miles I recorded 6 more events. Took it into the Dealer and they said they could not verify any issues. I was totally disgusted and traded the XLT in on a new 2025 Lariat thinking that I wouldn't have any problems with a different truck. Well, I was wrong, at 611 miles the Lariat transmission did the same thing 3 times within a week. I again took it into the Dealer and again they could not verify the events. Then the same problem occurred at 1,100 miles. This time the Dealer more-or-less blew me off by giving me a Ford print-out covering the 10R60 Transmission and stating in short, the Klunk & Jump "is a normal and desired behavior of the 10R60 transmission". I now have 2,800+ miles on the Lariat and the same Klunk & Jump resurfaced twice just 2 days ago. The Klunk & Jump as I call it could be a low thud sounding noise followed by a subtle movement or a loud metallic noise followed by an aggressive lurching movement. I just don't see how a transmission that makes disturbing noises and movements is not considered defective. I also feel transmission problems will no doubt surface down the road and most likely when warranty expires. Ford needs to own up to a poorly designed transmission. Perhaps a class action suit needs to be instituted.
HAS ANYONE EXPERIENCED THE SAME PROBLEMS??????
Petr
WA
2025 Ranger 2.3L
Every Ranger is equipped with a start/stop disable button. Don't be a lazy , push it. Majority of 10r60 issues stem form this utterly stupid feature!
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
Never any issues like that on my 25 XLT. Sorry you are dealing with that.
I know people love to hate on the auto start stop, and to each their own, but what transmission issues does it cause?
03GeeTee
Oklahoma
2025 Ranger stx 4x4
LangWWilliams
Langley
Ohio
2026 Raptor 2016 Harley Street Glide
mostly retired
The auto start stop lets the transmission lose hydraulic pressure an the clutches slam back into lockup (at least that's what some internet engineer claims). I've also heard it's hard on the cam phasers since they rely on hydraulic pressure too.
I had a 2019 for 46K miles and never had a transmission problem but read about a lot. A few guys got lucky an found the trans under filled from the factory an that helped them.
DESKPOP
FarNorcal
The Explorer ST guys have spent a lot of time tweaking the transmissions on their rig. Many of them swear that filling the transmission to 2.5 or 3 on the dip stick makes a huge difference in shifting quality.
hand-filer
Fred
When new, mine would lurch going from 1st to 2nd after a cold start (at normal idle) and only on the first shift.
Zero shifting issues with the transmission since around 3,000 km.
I like this transmission, a lot.
I have A.S.S. disabled.
Not-So-Good!
So. Jersey
2025 Ranger Lariat
Hey guys, I appreciate All the input. The dealership never mentioned anything about the Stop/Start switch. I deactivate it the moment I start the truck. I hate it! I guess I'll have to live with the piece-of-shxt! At 77 years I'm tired of putting out good $. GOOD LUCK with your Rangers!
I have not had the issue with my transmission but I feel bad you are. I understand abou being mad about it being messed up. None of that is normal for a transmission to do
fordc51
Jim
Cumming, Ga
93 f150, 2025 ranger xl
I have a 25 xl with 4k miles. Shifts great. It really sux to get 2 bad ones in a row.
Ford needs to mske it right for you.
Johnnypedals
New Jersey
2025 Ford Ranger xl stx
Machinist
Sorry to hear about the issues. I think a lot of the issues and odd behaviors people are felling (myself included) are just the nature of these 10 speeds. They definitely don't feel the same as the old school automatics I grew up driving. Best of luck with your truck and hopefully it will smooth out with time.
Aftermath865
Clint
Knoxville, TN
2025 Ford Ranger XLT Sport 4x4
Appliance and TV Repair technician for Best Buy’s Geek Squad
I’ve experienced the issue to which you are referring. It’s not all the time. Very intermittent. May do it a couple times in a week, then may not do it for over a month or more. Only happens on start up when it does occur. I’ve had my truck for 7 months and put 5,500 miles on it. Truck drives great and shifts like butter though.
I haven’t heard it in over a month now. But if I had to guess I’d say it’s done it 20 times since I bought it. Sometimes it’s light and not real noticeable, and a couple times it’s kind of gnarly sounding. I was able to capture one of the worse ones on video though.
Kian
NYC
'26 RR Avalanche Grey
Woah. That video is alarming.
I park my truck everyday on a driveway, and I’ve been getting used to the habit of putting it in neutral before the putting the ebrake on, then shifting into park.
no idea if this even relates to this issue, but I haven’t experienced anything like this video at all.
