Aftermarket rear diff cover Non raptor
Awirez
That's awesome to know! I hope Ford is working to improve the paint issues that some have complained about.
Can you post some pics when installed?
josephp732
Joe
NJ & FL
100% will post up some pictures. Waiting for the Amsoil Severe Gear 75W-85 to show up so probably get to it next weekend.
josephp732
Joe
NJ & FL
Completed the cover swap out. I was very surprised how heavy the factory steel cover is. If the differential had a drain plug I would not have bothered swapping them out. Two other surprises are that the gaskets for the factory cover and Ford performance cover are very different - see picture and that the factory cover is installed and then the axle and cover are painted. When I took off the factory cover I had a paint ridge that I had to scrape off so the new gasket and cover could sit flush on the housing. As others have mentioned the paint quality is so, so on the new cover.
Ford Ranger Aftermarket rear diff cover Non raptor 20250624_201101
Ford Ranger Aftermarket rear diff cover Non raptor 20250712_124627
Ford Ranger Aftermarket rear diff cover Non raptor 20250712_124920
Ford Ranger Aftermarket rear diff cover Non raptor 20250712_134715
Hootbro
Delaware
2024 Ranger STX 4X4
Looks good.
Yes, looks really good. I will probably do that pretty soon, also. I did a motorsport diff on the 8.8 on my 04 ranger so i could do fluid changes faster
Ford Ranger Aftermarket rear diff cover Non raptor 20250712_161320
garman
gary
Southern Idaho
How many quarts did you use, does this cover add fluid?
josephp732
Joe
NJ & FL
If you fill to the bottom hole (as per the instructions) it takes the stock amount 4.2 pints.
Awirez
I did some additional digging and came across a Ten Factory (Motive Gear) diff cover advertised for the Dana M220 on the Ford Bronco. Since the ranger has the same rear end it's a go! The hardware provided is the same as the Ford Performance diff cover has as well.
https://ebay.us/m/lO4oBR
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_085108
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_085113
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_085117
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_090540
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_100200
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_100211
Ford Ranger Aftermarket rear diff cover Non raptor 20260425_100217
Sparkherd
Sparky
South Central Texas
1985 F-250, 2026 Ranger XLT, 2022 Bronco Badlands 7MT 2 Door
Hi all, just wondering if they make a aftermarket diff cover for a non raptor 2024 fx4 with the locking diff.
I put the ARB cover on my 22 Bronco, fill plug, drain plug, dip stick, thick steel.
Works Great!!!
RB205
BB
Denver
XJ
So some very good news. I received the Ford Performance differential cover today and low and behold it comes with 2 longer bolts and spacers for mounting the brake line bracket that's on the 2025 Rangers :).
Any chance you can measure how long those spacers are?
I picked up a secondhand ARB cover a while back. It uses pretty standard M8x1.25 bolts, I'll just need to grab some M8 spacers and slightly longer bolts accordingly.
Afsigma21
OH
2024 FX4 Lariat v6
Air Force
Did the kit come with gasket?
josephp732
Joe
NJ & FL
This is very cool. I'll put one of these on my son's STX. Question: what did you torque the bolts to?
Awirez
Yes, it came with a gasket, the same type of flat gasket the Ford Performance cover uses.
The OEM gasket is reusable if not messed up. I purchased and used a new OEM just in case.
Awirez
Here is the procedure. (Model year 2025) 😉
Ford Ranger Aftermarket rear diff cover Non raptor 1780613863482-q1
Ford Ranger Aftermarket rear diff cover Non raptor 1780613903689-v
Ford Ranger Aftermarket rear diff cover Non raptor 1780613930197-7f
