Auto start/stop -- disable / delete?
Klassen580
Derek
Cyyc
2022 F150
Driver
Has anyone found a way to eliminate this on the 6 gen ranger? I sure don't like it on the 2.3l
Dubfound
Earth
BMW
It's weird. In my ranger raptor it didn't activate for the first few hundred miles and just did today? Oh maybe that because I typically keep it in sport mode. Haha
RaptorBlue
Chad
SW Florida
2021 Ranger Tremor/2023 Bronco Badlands
Ford salesman
I got a tune from 5-Star Tuning for my 2021 Tremor. When you are ordering it one of the questions is would you like auto start stop disabled. So the tune permanently disabled it. Now every time I start the truck the off light is automatically on the auto start stop button. Or you could put in a light up hitch cover that plugs into the 4 pin. Or Forscan. Or a dedicated obd11 port auto start stop eliminator. Lots of options to kill it. I didn't eliminate it in my Bronco and hated hitting the button every time I started it so I get it.
BriSco
'24 Ranger XLT, 2.7L V6
I ordered an XLT last month and the order update from Ford shows Auto Start/Stop delete as an added accessory. Not something I specified, but hope it makes it on the build.
I use to work for Oreilly Auto Parts and their trucks have Auto Start/Stop delete as an option on the window sticker.
fordtrks4ever
Perkiomenville, Pa
They are all listed like that
They all have start/stop
I agree 100%.
‘I think there has not been a single owner on here or YouTube that have taken delivery of a 24 Ranger without it being on there.
Here is the member and company info from the Australia company that I bought my start stop eliminator from.
Heres the solution guys. I own RA Ranger Australia and we ship many of these eliminators out to guys in the US with RR's!
It will automatically turn off stop/start for you on every start up! Best of all, the button is still functional if you ever need it turn it back on again. Fully plug and play.
https://raranger.com.au/products/ford-ranger-everest-start-stop-eliminator
Mikefili
Delray Beach Florida
2023 Ranger, 2004 Ranger
Construction
on both my 22 and 23 Lariats I simply unplugged the little jack plug on the negative battery terminal, that disables the start stop, I do know that some have said that unplugging that jack can cause a problem with the trucks, I did it on both of my prior rangers without any ill effects that I could see.
BriSco
It is an installed option. Available on fleet trucks. Oreilly’s Rangers and Mavericks do not have auto start stop. Nor the button to do so.
Aircraft examiner
And amazon has a cheap 18 dollar one that also works
Nuke
Jax
2024 Ranger 4wd Cactus Grey
I am looking now...thanks...but they all have some wierd fuses and an extra plug in that i see
Aircraft examiner
It is a wire you run to the fuse box. I bought that one for my truck and my son's truck and you just plug in the main part under the switch in the center console and run the red wire under the cobsole edge and under the steering wheel to plug in the fuse box. It takes 20 minutes or so, and that gives you time to drink water and make sure everything is ran smoothly and properly
Nuke
Jax
Thanks...Im not gonna do all that. and those are like $48 now...Ill just get the 4D tech
