Factory spray in bedliner scrapes easily
BlancoRaptor
BlancoRaptor
Warren
Arizona
Hi Sweek
Thanks so much!
I will order today
if you are worried about spray or roll in liner getting into holes and stuff, put expanding ear plugs into the holes. we do that in our paint shop on helicopter transmissions and gearboxes. they seal perfectly and are quick to put in and take out
Here's a pic of mine (some stuff in the bed), but you can still get a good idea of what it'll look like.
dang. that looks good
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
Perfect idea! And I have a bunch of them on hand.
BlancoRaptor
BlancoRaptor
Warren
Arizona
Sweet
Will it fit the bed of a 24 Ranger Raptor?
Sparky62
So Cal
I bought this one from Amazon, bit was perfect and a lip around the perimeter so that most any water doesn't run off the edge and end up under the mat. Quality seems very good and I'd buy again...
Any issues with water getting trapped underneath is between the mat & liner causing rust?
Not if the bed has been spray lined. My '21 didn't have spray in liner. I installed a bed mat from Ford. The problem wasn't water being trapped; it was dirt and grit that will work its way under the mat.
FYI, this is the type of mat I had. It even covers the tailgate. It's a tough rubber/plastic surface with padding under it that molds to the truck bed ribs.
Genuine Ford Heavy Duty Impact Bed Mat - VR1WZ-9900038-A | Levittown Ford
Sparky62
So Cal
@Jason B - Ok, thanks, I plan on having Line-X sprayed after I take delivery, then I'd like to add the TripleAliner you posted the Amazon link to earlier, looks like a great combo to protect the bed.
I have Line-X in my F150 now, love it, but I have to put something down when I'm sliding nice things in and out to avoid them getting scratched by the roughness of the Line-X, that TripleAliner will solve that for me.
rocsteady
New Jersey
Federal LEO
I'm thinking about Line X and wonder about prep.
The bed has the tie down cleats and a number of unused threaded holes. I'm thinking it might be wise to remove the tie down cleats and then put bolts in those and all the other threaded holes.
It seems like the Line X folks would cover or otherwise consider these things. I'll ask specifically in advance.
They absolutely covered right over all of that. I had a heck of a time getting enough of the line-x off in order to remove the torx bolts when I needed to remove the tie downs to install a swing out bed box. Stripped one that I'll be pickup up a replacement for at the dealer tomorrow. Only come in a bag of four I was told so I'll have extras for next time!
CarTuner
Australia
Next Gen Supercab Ranger XLT BiTurbo
My factory spray-in bedliner seems to scrape easily showing a whilte residue !
Anyone else experience a "not so tough"
Factory bedliner? I would think it would be tougher and harder and more resistant to scraping when carrying items in the bed!
I had a Spray In Bedliner on ma XLT before I got a service body and i used it for wood cutting loads and even a full tub of quartz pebbles and never had an issue. just water blasted it all off and out. If you genuinely having some splitting and chipping, I'd say talk to Ford.... Sounds like it wasn't prepped...
sweeks888
Richland, WA
Well, I've also installed a Leer tri-fold hard Tonneau cover that prevents almost all water (self-wash at car wash, a very small amount leaks in, prolly forced under the rubber seal at the back of the cover), and so far it has all gone onto the rubber mat and when lifted, I see no evidence of water under it.
Boosted6G
PNW
2025 Vel Blue Raptor
This is pretty normal, even for aftermarket. I had LineX in my last two trucks and it behaved the same. It's a rough surface. Anything you drag on it will leave some kind of mark. It's not the liner getting damaged, but residue for whatever you're dragging. It's like sandpaper.
burbansk
Bruce
Mio MI.
2015 Ford F150 FX4, 2024 Ford Ranger Lariat FX4
I had the Ford tough spray in liner in our 2024 Ranger XLT and thought it was well done. Unfortunately the cab had a bad water leak and Ford bought it back. We then bought a 2024 Ranger Lariat but it did not have the spray in liner. I put a Weather Tech liner in and it fits great. Will probably do the Line X this summer.
