Ford App Autostart
GFoster85
Garry
IL
aviation
Anyone else unable to start their truck from the app? Just gives me the spinny wheel of death.
Ford Ranger Ford App Autostart IMG_7523
I have never tried mine from the app just use the fob to remote start it. Just one of the many things that I don't use on my truck :LOL: like charging pad, bed power bank
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
if your wifi or data is weak, or slow it will do that. I find when it does that, its mainly my wifi is very weak, so I turn off my wifi and data takes over. or vice versa. Im off wifi and no cell service
BHunted1
Sumner County, TN
2024 Ford Raptor Ranger
Started going into sleep mode a few weeks ago. Now it happens all the time. I monitor the voltage from the ecm when I drive and it also looks like it's charging weird. There is a TRM update. A ssm says could be causing battery drain. If so, an FDRS has to update it.
Of course, it's effing 14 deg for the next couple days.
Trimjb
Tennessee
2024 Ranger FX4
Mine works fine.
I tried it the other day.
Start and stop from the add.
I have not tried the scheduled start yet.
Lock and unlock doors also works.
fordgt
Once you get it working right from the app you can create a shortcut and control it by SIRI commands. I use it to unlock my truck as I approach it in store parking lots.
MasterCylinder
Jay
Retired, FF, CET, Mechanic
App remote start suppose to work over cellular, check your settings in truck and also make sure its added in the app properly. I can start mine from my house out in the country 150 yards from the truck and you can also set how long you want it to run. My Son started his and shut it off in another city from where he was with his phone. Security still works no ones going to just jump in and drive it off! We tested it! Lol
Medic 6
Rob
Greencastle, PA
Never used the scheduled start. Everything else works fine.
bigb
Tucson
2025 Ranger 2.7
If you have WIFI calling enabled your phone will automatically switch to WIFI when you're at home near your network, and it may not be a strong enough signal at your truck. Like @ShadowDragon24 said, switch off your WIFI and the cellular network will take over.
Mine starts instantly over either network but I also have a WAP in the garage.
twaderobyn
Tony
Joplin, Mo
2024 Ranger Lariat
Admin
Quite literally just started mine a sec ago and came here to see what’s up and saw your post.
BrentZ
Ontario, Canada
2025 Ranger - FX4
Mechanic
The app also lets you set the HVAC. Plus start it when you are too far for the fob. You can also program it to start daily at a set time. One of the best features of the truck I think.
Hande
Hannu
Estonia
Business Owner
I use it frequently, works like a charm.
Great to have HVAC and heaters do their job before entering the car.
patc890
Patrick
Rockville, MD
Interesting. In the last few weeks I'm having trouble starting with the app. The truck is close by and I'm in my house with strong wifi. Sometimes it starts and sometimes it doesn't. But your comment about the battery is what caught my eye. I've been having trouble with my battery. Without the engine started it often says 11 volts and even with it started it sometimes says 13 volts. I get messages about Charge System Fault and Remote features disabled and the battery fault light on the dash. . I've had it to the dealer twice and they say it fine?
Hande
Hannu
Estonia
Business Owner
I had recently similar kind of symptoms - dealer replaced battery under warranty and all electrical issues are gone.
patc890
Patrick
Rockville, MD
Thanks for the reply. I can’t convince my dealer. The problem never shows up when I’m there. I’ve shown them photos but they just keep saying it’s ok. I suppose I’ll have to hope it gets worse.
