mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Email sent. I'm hopeful that FORScan will put out an updated version soon with the included fix.
Received! Thanks a million! At work but will try it tonight. Keep ya posted.
Ragner
Victoria
2022 ranger XLT
Supervisor
Has anyone gotten trail turn assist to work on a stx with 4x4 and dif locker? I have the off road screen thing on I put it on mode 1 has the little car on the axis and all but can seem to get the trail turn button to work.
What is your original as-built for ABS
760-03-01?
DylanBra
24 Ranger XL
760-03-01?
yes the block is 760-03-01 that I was trying to change and then the numbers after were something along the lines of 6B85-5B
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 92680706-4E9C-4F8E-9578-3066846E30F2
Ragner
Victoria
2022 ranger XLT
Supervisor
TTA required reading the G-sheet section of the spreadsheet and changing the
760-03-01 xxxx XXxx to suit. I can help of you give me your exact original block code.
DylanBra
24 Ranger XL
That would be awesome, currently have it in the shop for a axel issue once I get it out I’ll send a pic!
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Got an update for the 2025 MY Rangers. I worked with FORScan and did the testing they requested and provided them log files. They provided a fixed/test version of software based on 2.3.66 and I confirmed this morning that programming of the IPC module now works. I made 2 simple changes using the non-AS BUILT menu and both were successful. I'm sure they will release a patched version at some point but if anyone wants the test version DM me and I'll email it to you.
It worked! Thanks a million! ??
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
anything in forscan to override his app and let it run in drive and not just park
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745453867218-zy
renato23
Renato
Brazil
Ranger Black 2.0
I'm having trouble writing on BdyCM Module in my friend's car. I have done it many times in my own car, but on his specific vehicle every time I try to write the changes on that module I get the "Service procedure has been interrupted" message.
Any ideas?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745508628198-i1
renato23
Renato
Brazil
Ranger Black 2.0
banjo5
Chad
NC
2020 F250 6.7L, 2024 Lexus RX500h
Any ideas?
What year is the Ranger you are trying to program? Are you running the latest version of FORScan? FORScan support told me that when upgrading you should delete your vehicle profile and rescan with the new version.
mrjofus
Kevin
Fort Collins, CO
2025 Ranger Lariat FX4 2.7L
Worked for me as well, thanks! I couldn’t even connect with 2.3.65
TJPresley
Conway, AR, USA
2025 Ford Ranger Raptor
Trying to get caught up with this thread. I can't even get Forscan to save anything because every request gets the interrupt error. Is there a way to always start up in Raptor mode? I know someone made a wire harness that bypasses auto start/stop. Could there be a method to do the same thing to put it in Raptor mode if we can't do it with Forscan? I'm going to wear out that button lol.
renato23
Renato
Brazil
Ranger Black 2.0
Is it possible to enable rear camera view at speed? Guess it would be useful while towing.
Have anyone ever seen something about activating the front parking sensors? I'm going to try to activate and install it.
Also, I have some questions about the spreadsheet. What does those itens really do?
- Auto relock (Sync Menu): have no clue what this one does.
- Welcome lights (approach detection): I guess the car will turn on some lights when it finds the key nearby. Is that correct?
- Powerpoint timeout duration/configuration: I guess it has something to do with the power supply on 12V outlets. But what exactly does it do?
- Disable Auto Stop Start Feature (only affects cluster visibility/nag): it removes the start/stop icon from cluster, is that it?
You pretty much answered your own questions. As for relock, if you unlock the truck with your fob and don't open a door in the preset time, it'll lock the doors again. It's handy, but I stopped using it.
Yeah, i turn that auto lock off too
