egecikrikci
Ege
Turkey
Ford Ranger Wildtrak 25'
Just picked up a 2025 2.0 Wildtrak w/ 360 cam + radar pack. It should have Intelligent ACC (stop & go), but turns out — nope. Ironically, base Wildtrak in TR has IACC, but the higher 360 pack doesn’t. Guessing Ford limited it due to compute constraints?
Anyway, my truck has full radar, EPB, electric brake controller, etc. ACC works but no lane centering, no stop&go cuts off below 15kmh -and lane assist just lane bounce. Want to enable IACC + Lane Center + Traffic Jam Assist via FORScan if possible. Anyone pulled this off on a 2023+ Ranger?
Jeffola
Southwest Florida
Business Development
Note that on this sheet, if you are looking at any of the settings on the "TBD" tab, the cells are shaded yellow which means they have not been tested yet by anyone here and thus may not be accurate. On the "Confirmed" tab they are shaded green and at least one person here has confirmed it works on their truck.
Having said that, note that the this was still TBD when you tried it, and that version said to set the value in the APIM to 8, which is not accurate. I finally got a chance to check this out (sadly I did this because I had to tow my boat to the shop for a blown cylinder), and can confirm it works on my NA Lariat with basic Tow package. But the value should not be set to 8, instead you should "add 8" to whatever is there already on 7D01-02-03 (in my case I had a 5 there, so had to change it to D). But the recommended setting for the APIM part is to use the "non Asbuilt" and instead of messing with bits and bytes - just use the drop down to enable "Turn Signal Views".
** Make sure you also make the change to the IPMA module, which does not have a non as-built menu option, so that one you can just add 3 to enable both cameras (in my case it was 0 so I changed it to 3)
Here's what it looks like now that I have confirmed it works. Note that Ford may still disable this if there is a limitation in your country.
Been searching this thread (Like we all do) and dowering if the mirror mode works without a trailer? Of course I am asking for a friend.
dudufritzen
Eduardo
Brazil
Ranger Limited+ 2025
I went to enable Trail turn assist and my abs section doesn't match what the spreadsheet has.... The 760-03-1 part... I have a 2025 US spec
I have a 2026 Argentina ranger and I'm experiencing the same problem, we have 3 ABS blocks with completely different coding than any spreadsheet. I tried adding 8 to Hex, but Forscan doesn't record and displays the message "Service procedure has been interrupted". Does anyone have a solution?
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
It has been a while since I posted here. Had a problem with my scanner and had to buy a new one.
Now i'm trying to activate the rear camera at speed. Does anyone with just the rear camera was able to do it? I have a feeling it only works with the 360 camera system.
I was able to enable this icon at APIM module, but when I click it nothing happens.
I'm also wondering if there's a way to activate Alexa. At APIM module I enabled it but can't find it anywhere. Any ideas?
I was able to turn rear camera on at speed. That is the only camera i have. Also made the "full view not available go away. Its in the spread sheet here on the asbuilt sheet. Works like a charm.
2024, 2.3l, xlt, 4x2, advance tow, elocker.
Matiasjf
Matias
Argentina
ranger 2024 black
abogado
Hello, could someone tell me the steps to activate and operate the automatic air conditioning with Forscan?
craigc
craigc
Craig
Allen, TX
Not sure I exactly follow your question, but if what you are asking is if the camera turns on on when left or right blinker is on but with no trailer, it does not. it only works for me when towing a trailer.
dsmclark
Sam
Dorset
Ford Ranger Raptor
Has anyone had any luck making changes on the PCM module?
I’m pretty sure the second digit in the field circled should be 4 and when I put that in it gets to about 80% then fails. Not sure what the 6C means either. Anyone else here with a ranger raptor that can post a screen shot of what theirs shows. This is to try and get the active shutters on the intercooler to open. Thanks
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_1273
SolarWinds
PNW
IT Director
I did the coding for the glare free high beams and went on a test drive last night. Very cool feature. I should have enabled it a while ago
radial
Rich
Maryland
It really is an amazing feature! It took me a couple of tries to get the coding right, but it was totally worth the effort. If you ever drive on poorly lit roads, this mod will rock your world.
egecikrikci
Ege
Turkey
Does anyone know what is the pre req of glare free headlights ?
Believe there are two different headlights one is matrix and second is base led ??
renato23
Renato
Brazil
Ranger Black 2.0
Can you share with us exactly what you changed?
renato23
Renato
Brazil
Ranger Black 2.0
Hi,
I have an argentinian Limited+ (3.0 V6 Diesel). I have been able to add many options using Forscan such as driving modes, TTA, instrument panel gauges, seatbelt message off, etc. However, there a couple of features which are still giving me headaches....
For those of you with LATAM or EU non-Raptor Rangers, have you been able to enable welcome lights and/or 360/zone-lighting?
For welcome/approach lights I have tried the modifications as explained in the spreadsheet but lights do not come up, even though that the option is enabled in the center screen.
For 360/zone lighting, I have been able to add the option in the center screen -and even enabled 360 lighting in BCM- but everything is grayed up....
@Sequoia , @renato23 , any luck of these features?
Thanks,
Ramiro
Any updates on the welcome lights thing? I have tried to activate this feature in another friend's car but it did not work.
ramiro_mdq
Ramiro
Mar del Plata, Argentina
Ranger Limited Plus 2025
Still struggling with zone lighting.... My battery seems to be low, so I cannot test with the engine off. And when trying to test with engine running, I get a message saying that transmission should be in Park; it seems something seems to be missing for letting APIM know that transmission is already in park....
I have learned some things along the way, though. Like enabling GWM for APIM being able to communicate with BCM about Zone Lighting (716-02-01, 716-14-01) and APIM behavior changing depending on the selected LVHMI vehicle (7D0-01-04); eg: NA vehicles can enable zone lighting feature in APIM with engine running but ECE vehicles can't.
I hope my battery charge fills up after a trip next week, so I'll test whether zone lighting works with engine off, and keep on trying to make it work with engine running too.... If I succeed, I'll share my findings here.
This being sayed, I have not tried modifications related to welcome lighting and would leave them for when I get bored of trying to make zone lighting work.....
Texas Ranger
Austin
I'm having trouble finding information on how to do this, do you mind sharing your method or source?
radial
Rich
Maryland
This post from user moproblems shows all the modules and the values you need to change using FORScan to turn on the glare-free headlights feature. Just be sure to backup each module beforehand. This one involves changing a lot of values in a number of modules, so you want to make sure you can recover from any data entry errors. Good luck, and let us know if you run into any problems.
https://www.ranger6g.com/forum/thre...sourced-spreadsheet.12611/page-17#post-226557
