alrashid2
PA
Having trouble finding an answer here and hoping maybe somebody can dumb it down for me?
I'm a bit confused on how to do the adjustments within Forscan. Here is an example I am trying to do, which will remove the "Full View Not Available" from the rear cam:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787236679768-z1
I see the value is APIM 7D0-02-02. But that's where I get lost. What exactly am I changing here? I don't understand what the 3 Value Change columns mean (xxx*, xxxx, xx--) and then the * Bit 1 explanation...
Don't really get bits and computer talk. Could someone just show me what I'm supposed to change here?
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
You
Change the * to whatever it says the change is in that spot of your as built. Your as built will be in blocks of 4 4 4. Hence XXXX XXXX XXXX. The * is what you change.
alrashid2
PA
You
Change the * to whatever it says the change is in that spot.
Will give it a shot thank you!
I asked AI as well, not sure if this all seems correct...
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1787237129389-s1
Loudpa
So that I understand as well say they had:
(1112, 1234, 99--)
would become
(1113, 1234, 99--)
RCMUSTANG
Ray
Los Angeles
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
It is highly recommended that you back up any modules PRIOR to any change, that way you can easily restore it to factory if you mess something up.
Or, I take pictures of the screen so I know what was there if I do a bunch of little changes
mrjofus
Kevin
Fort Collins, CO
2025 Ranger Lariat FX4 2.7L
I’m guessing that’s Gemini? ChatGPT is pretty good at Forscan and just helped me with the glare free high beams on my truck. If you want to go with AI that is
jtvjr82
Joe
Poulsbo, Washington
2024 Ranger Lariat 2.7
Does anyone know if it’s possible to code a numerical value below the oil temperature gauge? I used forscan to get it for the coolant temp and transmission temp but have been unable to find anything about oil temperature. 24 Ranger Lariat 2.7
joordan
Italy
ranger wildtrak 2023
Yes, it’s in the file. I have numerical values on all my gauges
joordan
Italy
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet imag
RR24
yaser
dubai
ranger raptor 2024
Hi everyone,
I have a 2024 Ford Ranger Raptor 3.0 V6 (UAE/GCC spec), and I’m looking for the correct FORScan settings to enable the following features:
* DTT – Digital Transmission Temperature
* DEOG – Digital Engine Oil Gauge
* TPMS Tire Temperature (temperature + pressure display)
* TSR – Traffic Sign Recognition
Could anyone who has successfully enabled these on a 2024 Ranger Raptor share the exact module and As-Built values (IPC/IPMA/etc.)?
For TSR specifically, I’m looking for settings that work correctly with UAE/GCC road signs. If TSR requires changes in both IPC and IPMA, please share the exact values/settings used.
Thanks
joordan
Italy
Hi everyone,
Thanks
All in the spreadsheet..
