midnight270
NNJ
2025 Ranger Raptor CGM
@Patriot_USMC Try following these steps exactly. Don't listen to Google AI or where ever you got those steps.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1788868592339-rx
Do these in this order. IPMA, SCCM, IPC, HCM, APIM. The settings below are for matrix lighting.
IPMA
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet MATRIX LIGHTS STEP 1
SCCM
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet MATRIX LIGHTS STEP 2
IPC
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet MATRIX LIGHTS STEP 3
HCM
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet MATRIX LIGHTS STEP 4 AND 5
APIM
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet MATRIX LIGHTS STEP 6 AND 7
midnight270
NNJ
After I changed the modules I needed to cycle the ignition on and off a few times for it to work. You'll know it worked when you go into the Lighting settings for the truck and see "Glare-Free Lighting"
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_1427
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_1425
Albanogc
Albano
Brazil
Ranger Black 4x2
Hi mate, I hope you are well.
So I'm stuck in the same spot as you with these gauges.
Turbo and Oil Pressure Activated in IPC, but they don't show any info.
Have you figured out how to make it work?
Mine is a 4x2 so I haven't enabled those modes, but, about Rock Crawl and Ruts, the biggest differences seem to be H and L.
https://media.ford.com/content/ford...selectable-driving-modes-enhance-on--and.html
Hi guys, good day to everyone.
Has anyone found how to make those gauges work?
Mav R
Tried enabling glare free high beams tonight on my 26 Raptor. Tried twice and each time I ended with 4 diagnostic codes, so I rolled back the changes.
DTCs were:
pscm - U023A:00-28 (lost communications with image processing
module A)
RCM - B00DF:4A-08 (passenger restraints disable switch - incorrect component installed)
HCM - U2101: 00-08 (control module configuration incompatible)
IPC - U0415:00-08 (invalid data received from abs control module)
Not sure what the issue is but it feels like something has to have changed?
DTCs were:
module A)
Have you been able to revert the changes and clear the DTC's. I have similar issues and can't clear the RCM code
JJT
JAVIER
SPAIN
RAPTOR 3.0
Hi, has anyone configured the windows so they automatically close when locking the vehicle with the key fob?
SnyperX
Mark
2024 Ford Ranger XLT
I can close mine via the keyfob by pressing lock twice and continuing to hold the lock button , windows will all close.
Well I was able to enable the matrix lights, but I have several HCM errors that I can’t get cleared. Ideas?
Try starting it a few times and see if it clears itself. I notice sometimes forscan takes a few key cycles for stuff to fully work
Ag3ntC00p3r
Product Manager
I don't know if this will help those that are trying to enable the Glare Free Matrix Lighting, but I saved my changes and cycled start mode/power after each module change. Not after every individual change, but after all changes were made in a particular module. I have zero errors after enabling mine.
Patriot_USMC
Central Oregon
I did 3 cycles back to back, 1 minute ACC power on, 1 minute off, followed by locking the truck with the fob and walking away for 15 minutes. And I've driven the truck 5 or 6 times since and it's still the same.
Dang. Hmm, I dont know than.
JJT
JAVIER
SPAIN
RAPTOR 3.0
Thanks
Sure, that works, but I mean something slightly different.
I’m looking for the windows to close automatically with a single normal press of the lock button, without having to press twice and keep holding it.
RA Ranger sells a programmer that enables exactly that function, so I’m trying to find out whether the same setting can be enabled manually with FORScan:
https://raranger.com.au/products/global-close-windows-programmer
