Let's Talk Tire Air Pressure! (Raptor)
oldskoolarcher
Nick
Central PA
'24 RR, '24 Defender, '01 TJ
What air pressure are you guys and gals running in your stock Raptor BFG AT KO3's? It seems as though many dealers aren't adjusting/lowering the pressure in the tires after shipping. What are you running for the best contact patch?
@Ford Motor Company What do you recommend?
Thanks
Bt_okst
BT
Ok/Colo
Thanks
It's listed on a label or the driver side door jam, 39 psi.
Ford Ranger Let's Talk Tire Air Pressure! (Raptor) 20240429_142840
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
I wouldn't count on the Dealership adjusting the tire pressure after it arrives.
My Bronco arrived with 50 psi in the tires and was shipped to me with the same psi. I had to adjust it down to 36 psi (the sweet spot for noise and ride, for me) once I got it into my garage.
AlphaRR
Eric
Alpharetta, GA
Porsche Macan S
Mine was at 45/46 cold... was feeling every bump until 42. Thinking I will get it to that 39 spec per the sticker.
markal49
Mark
2024 Ranger XLT w/ FX4
Planner
I have an XLT, not a Raptor, but the dealership had them at 42 psi when they should be at 30. The drive home was punishing!
jrRaptor
Maize, KS
39 cold in the cold but the weather has warmed up so the pressure has increased.
Machduty
Chicago
2024 subaru outback wilderness, 2018 superduty,
Bricklayer
The ride improved a lot in my opinion not as bouncy smoother over bumps can't comment on gas mileage truck only has 400 miles and I do a lot of City driving.
Deleted member 6842
The European market has two tire pressure ratings, empty and full load. The same pressure applies to the 2 Liter Diesel (not available in the US) and 3 Liter EcoBoost.
Empty it is 36 psi (2.5 bar) front and rear.
Full load or towing is 36 psi (2.5 bar) front and 41 psi (2.8 bar) in the rear.
At 36 psi I found tire wear to be very even on my mostly unladen Ranger Raptor.
24'Ranger
Kevin
MN
2009 Vibe AWD, 2019 Outback, 2024 Ranger?
I wish the US would like the tire pressures like this.
