Mud Flaps, yay or nay?
isslandboy
Greg
S.E. Alberta, Canada
2025 Lariat, 2014 Toyota Fortuner
I have had mud flaps on almost all my vehicles, but the Raptor looks so good without them, I am hesitating getting some. I will rarely take it off road. There is plastic trim protecting the lower rear, and the running boards adds protection up front. But at about $150 for a full set of Weather Techs, it's not expensive protection. Do you all have them? Which ones? How do they look?
You may want to check with the local authorities, some places they are mandatory.
got3fords
got3fords
James
Central Va.
Interesting. Although, if they were mandatory, they should have come with them. Like here in Va., front license plate holders are required, and are a line item on the window sticker.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
I added the factory flaps after I constantly kept hearing rocks clatter around on the sides/under the truck on the freeway. Haven't heard a thing since. I went oem because I preferred their look, but I hear there are now oem knockoffs for much cheaper. (There's a thread on here somewhere, sorry I don't have the time to find it right now). They were relatively easy to install, but the plastic push pin connector dealies can be annoying. They like to not back out without help. I used an awl to get under the screw head of a couple and get the threads to grab.
got3fords
got3fords
James
Central Va.
Thanks for the heads up on the pins.
got3fords
got3fords
James
Central Va.
The Ford Performance blend in nicely, mount perfectly, and seem to be doing exactly what they’re supposed to in the first 5K miles on the truck.
Agree, they look pretty good.
SLJ
The Finger Lakes
I went with these Kewwisauto flaps. I was told they look like Fords but blank where the FORD would be:
https://amzn.to/4dVgw0T
Haven't seen the FORD flaps so I don't know.
I ordered the Musolgy flaps first but returned them as they are not flat on the wheel side so they would collect mud and most likely get ripped off easier by debris hitting the lip:
Ford Ranger Mud Flaps, yay or nay? Muslogy Mud Flaps
https://www.amazon.com/dp/B0DFW9ZGRS?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2
snm928
Truckee
Ranger Raptor, VW Alltrack, X3, 328ic
Obviously, it's your truck and you know your needs and taste best.
My RR came with the Ford Performance factory mudflaps. While part of me agrees with you regarding the aesthetic appeal of the truck without the mudflaps, over time they have really grown on me from a visual standpoint. More so than aesthetics, I really wanted an extra layer of protection to the areas of truck that are prone to rock chipping/dings and so I almost certainly would have purchased the FP mudflaps if they weren't included on my RR.
I don't think there is a bad choice here. Really, it's just about figuring out how you weigh and balance aesthetics vs. utility; I can easily appreciate the RR with or without the mudflaps.
Agreed. Did not want to do it, but live in snow country. Flaps do not keep things pristine, but without them, looked like mud was sprayed on with a hose. I know the holes in OEM running boards contributed, but it is much better and I don’t notice them at all anymore.
got3fords
got3fords
James
Central Va.
isslandboy
Greg
They are mandatory here in Alberta Canada, but are not included in the base, must be added on.
Raptor_Logic
Washington
If anyone wants some oem ford performance off a Raptor DM me. I got 2 full sets.
